Error code f35 konica 7022
WHEN I GET TO SERVICE MODE THROUGH HOLDING 2 $ 5 THEN SWITCH ON THE MACHINE IS ASKIING FOR PASSWORD PLS HELP
  • 18 Answers
Turn on the main and sub power switches.
Keep pressing the
* button until the message
“Please enter service password.” appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press the key of the mode to be selected on the
screen. To return to the Mode Change Menu
Screen, keep pressing the
* button until the
screen appears.
When the adjustment ends, press
[1. Normal Mode] key and the basic screen will appear
Posted on Jul 16, 2008
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Hi, I have a Konica 7022 and it comes up with the error code PLEASE CALL SERVICE F-35-1 . Can anyone please advise a fix to this problem. Jack
I would call for service. Below is the official repair method. Sounds like a fuser has failed or at least the thermistor on the fuser. This ensures there is enough heat in the device to properly transfer the image to the page.
F35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Mar 01, 2011 | Office Equipment & Supplies
ON SWITCHING ON THE COPIER KONICA 2020 ERROR CODE F35 DISPLAYS PROMPTLY
How to clear fuser abnormality codes (F34, F35, F36), 2020.
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
If the code comes back then your fusing unit will need parts/service.
Dec 14, 2009 | Office Equipment & Supplies
Konica 7020 F35 - 10 Where is DIP switch 3
In mode 25, pwr off then holding 2 and 5 down turn on. Service mode 25 has SW setting find 03-1 should read 03-1-0 not 03-1-1 (1) is a code F35-10
Jun 10, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Error code F-36-2
Konica 7022 showing code f-36-3
Jan 28, 2009 | Office Equipment & Supplies
Error code F-35-6 on my konica 7022 copier
You could try to reset the code. F35-6 is a fuser code, either you have a power surge later or bad thermistor in the fuser unit. Power off your machine, while hold down 2 and 5 button power the machine, this should take you to the 25service mode. in the softswitch mode go to switch #3 turn bit 1,2 and 3 to 0. than power off and on your machine. if this doesn't work you need to replace your thermister and possibly the thermostat.
Sep 17, 2008 | Konica Minolta Minolta DI1610FP...
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
1,221 people viewed this question
k24674
jasbo
jasbo
