GE 24 in. GSD6900J Built-in Dishwasher Logo
A
Anonymous Posted on Nov 18, 2017
I have a triton XL model GSD6900 that does not fill with water. I replaced the fill valve about 8 months ago. Have checked the inlet valve and coil shows continuity. Ran it thru a cycle and found no voltage at the valve. I assume the problem is in the timer. If this is the case should I have it repaired or buy a new dishwasher.
Sal De
Level 3:
  • GE Master 2,699 Answers
  • Posted on Nov 18, 2017
Sal  De
GE Master
Level 3:
Answers
2699
Questions
0
Helped
1002665
Points
8029
Did you check the float switch?on the left side of tub there's a float switch,if it's stuck up in the air it won't fill,i've found that when the soap cup opens it dumps the soap down near the switch and the float can get stuck up in the air
  • Sal De Nov 18, 2017
    you don't have a timer in this machine there's a computer board,do you hear the machine start?if not first thing to check is the door switch or remove the bottom kick panel,there's a tech sheet there that will help you out,if it is starting but just no water remove the bottom panel,start it and with a meter check to see if power is coming down to the valve,you still could have another bad water valve or check the float switch,if that's stuck up in the air or bad you won't get any water,you can check that from the bottom or pop the cover off of the switch inside the tub and lift the float switch to see if it's stuck or on some models you can move it from under where the valve is.i would check these things before you get a new machine.good luck
    also next time send the full model number from what you sent 27 different machine numbers showed up but i checked a couple of them and they all had boards in them no timers.
Chris Huff
Level 3:
Top Expert:
  • GE Master 6,289 Answers
Chris Huff
GE Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2018702
Points
74913
Yes sounds like timer. Probably replace dishwasher depending on age.
5 Related Answers
A
Anonymous
  • Posted on Dec 26, 2007
SOURCE: ge triton xl dishwasher
will not drain
Anonymous
  • 111 Answers
  • Posted on Dec 20, 2008
SOURCE: GE TRITON XL REPLACEMENT SOAP DISPENSER?
Best way is to call GE Part at 1-800-626-2002 or go online to www.geappliances.com
Anonymous
  • Posted on Dec 30, 2008
SOURCE: GE Natulus will not fill with water
Had the same problem with ours today. That's why I got on here. My dad used a gallon jug to prime it with a gallon of hot tap water. We primed it to get it pumping, and now it is working fine. Just pour the hot water into the dishwasher and start it.
Anonymous
  • 111 Answers
  • Posted on Jan 02, 2009
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
Anonymous
  • 170 Answers
  • Posted on Mar 27, 2009
SOURCE: Ge Triton XL Dishwasher Fill Problem
I would check your fill valve screen, where your water line connects to the dishwasher, lots of times i will see that screen clogged, especially on customers homes that have wells.
There is no way to change the fill time on these.
There is also the potential problem with the float sticking if it is gunked up it will not allow water in...see that it moves up and down freely and you should here a clicking noise.....If it is not one of these there could be a problem...with the timer...I am providing a link that will help walk you through this problem in a more technical...manner...if you are not comfortable performing these tests...i suggest you forego it and let a tech handle it....
http://www.applianceaid.com/dish.html#filling (http://www.applianceaid.com/dish.html#filling)
this is one continuous link.....you can scroll down until you see the won't issue.
I hope this helps ..good luck, have a good day& please rate my effort......The Fang
We had a new control panel put in our machine awhile ago and we find that the hot water is much coole than before, can this be adjusted
Hi
You'll need to check for the water inlet hose, the water inlet valve and the temperature switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the temperature switch assembly should be replaced. Hope this helps... Please post back with the manufacturers name and complete model no if you need more information.
Daniel
MSD 27548DR* Water leaks from back when Ice maker is filling with water
I was answering another post and this post appeared after my last post. My sincerest apologies for not seeing it long ago. The symptom your describing is caused by the inlet water valve bypassing water when it supposed to be off. This can be identified by reaching back behind the icemaker and squeezing the rubber fill tube. If it is frozen solid with ice the inlet water valve is bypassing. The inlet water valve assembly is in the back of the unit behind the fiberboard panel in the compressor / condensor coil area. There are 2 electrical connectors and 3 plastic tubes connected to the water valve. When changing the water valve do a one for one tube swap so as not to have the ice maker filling when you select water in door.
The inlet water valve is item 4 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46544&diagram_id=28489316#d28489316
Thanks for choosing FixYa,
Kelly
1helpful
The water in the ice maker freezes solid instead of cubes; some of the spray overshoots into the bin. As a result the metal spiral turning fork gets jammed and comes out of its slot.
Hi and welome to FixYa. I am Kelly.
You are experiencing an inlet water valve water bypass symptom. What is happening is that the inlet water valve is allowing water to drip into the ice maker after the harvest cycle has long since finished. This is a common failure and all brands of refrigerator that are more than 5 years old. Replacing the inlet water valve will correct the over-fill problem. (I actually had to do this on my own 8 year old Maytag refrigerator not 6 months ago.) If you provide a model number I can point you to several on line sources for the inlet water valve.
Or you can just enter your model number on the following links:
http://www.frigidaire.com/productregistration (enter your model number)
http://www.searspartsdirect.com/partsdirect/index.action (Use the "Find it fast" window in "Model; search")
http://www.repairclinic.com/Shop-For-Parts (enter your model number in the search window)
If you do not have an inline water filter I would recommend that you install one at the time you replace the inlet water valve. It will keep plumbing debris out of the now inlet water valve and ensure a longer service life for same.
Kelly
Awhile back I had FixYa help me with my washer. It would fill up with water and then just stop. It turned out to be the lid switch. Now about a month or so later I went to wash a load of clothes and again...
Hi.
If the lid switch is OK and there is water getting into the machine, then test and replace the pressure switch that detects water level.
Here the part:SUB 12002304 (Water Level Switch Kit)
Part is nr 6 in this diagram.
Also test the inlet valve to ensure that dual inlet is working. If hot is not filling, the machine will not complete filling.
A technician can swap valve contacts to find out if
both valves are opening.
If there is no filling at all, check the inlet valve and inlet duct:Water Inlet Valve.
Inlet valve is at the back of the appliance. It can be tested reading Ohms at terminals.
1helpful
Water won't come into dishwasher
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most
2helpful
2answers
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
1helpful
Water pours into dishwashe and spills out when not running
sounds like you have a bad water valve solenoid, however their is a float switch on inside btm floor frt of dish washer that senses the level and cuts off the valve, however if the valve is bad then it will never shut off. good thing you were home. i would replace the water valve, that is located behind the front access panel . hope this helps
4helpful
My kemore 80 series washer will not fill up
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
2helpful
2answers
Need help with GE triton
That knocking noise is probably coming from your water line, and that happens when there is some kind of a ripple/wave effect when the water goes into your dishwasher (DW) thru the inlet/fill water valve. First turn your hot water valve off, underneath the sink coming from the wall and it usually is also going to your kitchen faucet. Then turn the electricity off by locating the breaker to the DW line and turning it off, or if it is plugged in an outlet under your sink, just unplug it. Then take the kick toe panel (panel with 2 or 4, 1/4" or philips screws) from the bottom of the dishwasher. You will then see the water hose, or could be a copper pipe, going into the valve (will have a selenoide, cylinder shape on top and have 2 wires plugged in to it). Unscrew the hose/pipe from the water valve and get a small wide bucket or pot and aim the hose/pipe to it. Slowly have someone open the water valve from under the sink while you hold it in the bucket/pot. If you hear the knocking again, you will need a plumber to check the pipes, hoses and water valve at your wall. If you don't here the knocking noise, just replace the dishwasher inlet/fill water valve part # 785330. http://www.repairclinic.com/0080.asp. Please post back.
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
