Question about AT&T Cingular 3125 Smartphone
3125 smart phone
The guts of the charger came out of this phone and stayed on the plug!!!! now i have no way to charge my phone and i really need it !!!
Test
Posted on Jul 14, 2008
With new batteries in a EZGO golf cart, when you plug in the charger when the batteries are showing half charge, the charger runs for about 15 seconds, shuts off for 2 seconds, and then back on.
How old is this unit? What is the model number? The newer carts have an smart charger that will tell what is wrong with a flashing code on the charging light.
Oct 23, 2017 | The Computers & Internet
My phone was charging 2 nights ago but I had to hold the charger a certain way and today my phone will not charge what do I do to fix it?
Sounds like the charging port has a bad solder joint, this can be caused by accidentally pulling the phone while it is still plugged into the charger. The charger isn't the problem and neither is the phone software the problem is the port itself has come loose from the board. It needs to be replaced.
Feb 02, 2016 | Cell Phones
Battery charger does charge this battery
Is the charger the right one? Check the voltage on charger and phone to see that they match.
Mar 13, 2014 | Straight Talk LG Optimus Zip Cell Phone
LG Optimus L9 Screen blacks when charger/usb-to-computer cable plugged in.
sounds like you have a usb cable for charging only.You need a "2 way " usb cable,the kind used to transfer music and pictures to and from phone to computer.These one way cables are usually used in mobile chargering,as you don`t need to transfer things,just charge.Or you got wrong cable for your phone.
Mar 02, 2014 | LG Optimus Black Smartphone
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
How do I charge my scooter I have lost my instructions
Look in your manual if you lost it then, go to razor.com and request one. But the simple answer is to:
1. Turn off the scooter
2. Plug charger into wall outlet.
3. Find the hole on the side that matches the charger plug(not the wall outlet plug) .
4. Plug the charger into the scooter.
5. Wait until the charger turn off ( if the charger is a smart charger), typical charging time is 4-6hours.
*If not a smart charger you can calculate the charge time by using an online battery charging time calculator.
Jul 02, 2010 | Razor E100 Electric Scooter
Charger connection broke where you plug it into phone. when i unplugged the charger the metal part came out still connected to charger when i plugged it back in the part stayed in the phone, makes no...
I have spent the last hour researching this..........
There is really no fix to this problem, and it's been a problem LG has had since the inception of this phone and they won't admit there is a problem. THere is numerous post about the exact same problem.
One solution is to buy a generic battery charger, you can find them on ebay. While there I would buy an extra battery so one can be charging while the other is in use, no down time.
Sorry I don't have a fix on this one :(
Please leave us positive feedback
Nov 27, 2009 | LG enV VX9900 Cellular Phone
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
Hello, my godmom just purchased a Brand new Blackberry Curve phone.When the saler put the battery in the phone, it didn't power on and she said that the battery was not charged and that we had to charge...
Its very hard to pinpoint the problem from your few descriptions. However since the light came on it mostly means the charger should be okay. As for the phone, if the battery is really dead, it sometime takes up to 30 minutes before it shows that it is charging. SO leave it plugged in for some time to see what happenes. If it did not come on after that then the phone is bad. Just to make eveything sure, you can also try any other MINI USB charger or a simple MINI USB cord to the computer to charge the phone with as well. They all work on the Blackberry
May 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
Will not charge or turn on using USB cable.
Two things.
HTC phones will not charge from the USB port unless you have ActiveSync on an XP or Mobile Device Manager on a Vista PC loaded.
Second, if the phone has been stored for a very long time, 1 year if initially charged, 1/2 year if not, the the battery self discharges to a point the USB port PC Sync software doesn't know the phone is connected. You must jump start a charge on the battery by either and HTC AC charger, a generic AC/USB charger will not work, or you can apply a +5 VDC voltage to the power terminal, marked + and - on the battery case, on the two outside terminals I believe. This 5VDC must be current limited for safety. The Red and Black lead inside a standard USB cable will supply current limited +5 volts at 100MA. Chop off a standard USB cable, their cheap and break out expose the Red and Black leads. While connected to the PC USB port, hold the Red lead to the + battery terminal and the Black to the (-), or other outside terminal, of about 30 seconds to a minute.
Now when you plug the phone to the PC with a good USB, the Amber light on the phone to indicate Charging, may not come on for a while, 5 minutes or so, but it will eventually. If it does not, jump the battery again for a longer period of time.
An AC charger for the 3125 are fairly inexpensive. $7 or so, on ebay with shipping. This may be the way to go. Consider getting one with a new battery. They are sold this way sometimes and sometimes for little more that the charger alone.
Oct 19, 2008 | AT&T Cingular 3125 Smartphone
AT&T Cingular 3125 Smartphone Logo
69 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
