Question about Freezers
Upright freezer condensation line sends water into freezer, creating a thick sheet of ice on bottom. i assume it's clogged. how do i unclog it?
  • teresabriggs Jul 14, 2008
    Mike, I'll give it a try- sure appreciate you!
  • 481 Answers
The water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 14, 2008
How do I stop freezer from leaking water
A drain plug is a small hole inside your fridge to allow for moisture to escape. The reason its leaking water is because its not cooling the water to ice or its defrosting the ice to water. make sure the door closes shut and turn it up a bit as it has been very hot recently
Aug 01, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Wood freezer f17wce bottom ice
There is water accumulation at the bottom under the basket it forms a thick piece of Ice that we have to break in order to remove it every second day what can I do ..
Feb 24, 2014 | Woods Upright Freezer MU07W
Clogged ice maker
1, ice maker may need to be replace, 2 water line may be frozen , if so turn off the freezer to defrost it for few hours, 3. when was the last time to replace the water filter? make sure you replace it when the time expired.
Sep 16, 2013 | Sub-Zero Freezers
The Freezer keeps freesing. I unclogged the drain, replace the thermostat censors in the freezer and i still have the same problem. Drain clogged with ice. What else should i do or test for?
Clean the coil. It's found either on the back or the bottom of the freezer. Use a vacuum or rinse with some soapy water in a spray bottle. Good luck!
Sep 15, 2011 | GE 17.1 cu. ft. Upright Freezer FUM17DTR
5 years - no problems, then started to ice up . Ice forms in the bottom and will develop 1 to 1 inch thick sheet in about 10 days
Check drain under freezer coils and clean out. Look out for frozen drain instead of trash Use hot water or turn off 24 hrs if that is the case. I usually insert a phillips screwdriver dowm in the drain and
pour hot water on the screwdriver so the heat transfers downm the screwdriver to the ice clog.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Maytag 15.6 cu. ft. Upright Freezer...
We have a GE 20.3 cu. ft. upright frost free freezer that keeps forming a layer of ice on the bottom, which we assume is happening when it is defrosting. How do we unclog the drain?
I let the ice box thaw out and use a shop vac to open the drain hole. You can find the end of the drain hose above the compressor drain pan.
May 28, 2010 | Freezers
Not cooling, but fan inside running
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Apr 06, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice built up on bottom of freezer then dripping down front
Probably a clogged drain. Use a pipe cleaner to unclog, then a turkey baster with hot water to clean out anything else. Then when the drain is clear, pour a weak bleach solution down the drain to kill the mold that probably caused the blockage If possible remove all food and let it sit unplugged for a day or two. This will clear some defrost problems.
Jun 22, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Freezers Logo
137 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
