That's d correct solution.i tried it and it worked.thanks
Hi, I think the speaker is getting damaged. When you strike hard keys, it makes crack sound i guess.
If you can open the keyboard and test the speaker by using a battery and run a wire to the positive and negative spot of the speaker. If you hear a clear sound after testing the speakers, that means the speakers are working properly,but if it does not sound clear enough,that means the speakers are not working well...
When a speaker does not sound good enough, it's usually a sound IC problem that will need to be replaced.
Hope that helped.
Feel free to pass your comment.
Thanks for using fixya...
