Question about Dell Inspiron B130 Notebook
Laptop Key repair
The backspace button of my Dell Inspiron B130 is broken. Is Bestbuy equipped to repair this problem?
    Problem Solver:
  • 14 Answers
I am not sure if BestBuy is authorized to repair Dell systems, but if they will take it, then they should be able to fix it. The fix will depend on the nature of the problem. If the key is simply poped out in some way, they may be able to re-attach it on the spot. If not, they will likely have to order the keyboard part from Dell, open up the notebook (or remove the keyboard) and replace it. On some computers this is easier than others. Most commercial lines of notebooks allow the keyboard to be replaceed easily by the end user without opening the case at all - just undo some latches and remove some screws, pop it out, pop the new one in, screw it down and latch it in. Some consumer systems (Inspiron is a consumer line) are not so well designed. It all depends.
Either way, BestBuy should be able to repair it. If you check with Dell first, you may find that you can even repair it yourself if it is designed to be a "user replaceable" part as i describe above.
Posted on Jul 14, 2008
My Dell Inspiron B130 won't turn on. The battery light blinks yellow twice then green, but that is the only thing happening.
Take the battery off completely and drain the flea power from the laptop by holding down the power button while the battery is off. Hold down the power button for about 15-20 seconds to ensure no power remains on the laptop. Check if your battery has a drain button too. Drain the battery and place it back on the laptop.
Charge it for about 30 minutes before you turn it on. See if it works.
Post here if you need further help.
Jul 30, 2011 | Dell Inspiron™ B130 PC Notebook
How do I activate the wireless connection for a dell laptop?
some netbooks have just one button for this(see manufacturers site/manual for correct jkey /key sequence) mine is Fn-F2--toggle on.off etc
Oct 23, 2010 | Dell Inspiron B130 Notebook
How do i turn the internal speaker back on in my Dell Inspiron B130 laptop?
It will be a combination keystroke--use the Fn key at the lower left side of your keyboard and one of the other keys (usually a special function key) that has a picture of a speaker on it.
The other thing you must check is the sound properties icon in the control panel and be sure your speakers have not been muted.
Sep 20, 2010 | Dell Inspiron B130 Notebook
Dell inspiron b130 laptop overheats and shuts down after about 1 hour of working... when I can start again it gives me a M104 error, but works again until the next time it over heats...
Sounds like your fan is blocked with dust, or it may be broken.
Google "cleaning laptop fan".
This is lots of great guides and youtube videos showing you what you need to do
Aug 01, 2010 | Dell Inspiron B130 Notebook
My backspace key does not work.my laptop is Dell Inspiron 640m. Thank you.
Your backspace does not work.... well could be many reasons, but if its the key itself, you can replace just the dell laptop key, if you spilled something then you will need a new keyboard, we really need more info. Good luck!
Jun 26, 2010 | Dell 0Y3740 Keyboard
Alot of keys aren't working.
================================= I have the same problem wih my Dell Inspiron 8000 and it had a keyboard issue with keys I, J, N, PgUp, H not working.
ut when I took off my keyboard and reseated the ribbon connector and it's been working since then.
=================================== Please read instruction for keyboard replacement: http://support.dell.com/support/edocs/systems/ins1300/en/sm/keyboard.htm =================================== If it still not working I suggest you get a keyboard replacement. ================================== Disassembly Tutorial for your Laptop: http://www.insidemylaptop.com/remove-motherboard-repair-dc-power-jack-dell-inspiron-1300-b120-b130-laptop/ ==================================
Let me know if you need further assistance. Please Rate. Thanks and More Power!
Apr 23, 2010 | Dell Inspiron B130 Notebook
My dell inspiron b130 boots up but monitor is black
After your laptop boots up into windows, hold down the Fn key and as your doing that press the F8 button that should switch the output from the vga connetor to the LCD screen on the laptop.
If you still don't get video then you'll have to reseat the LCD cable from the back of the LCD screen to where it connects to the motheboard.
If you still don't get video then its either going to be a bad LCD or a bad motherboard.
Aug 09, 2009 | Dell Inspiron B130 Notebook
I need to remove the administrators password for Dell Inspiron B130 service tag ends in 595B
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b130-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 28, 2009 | Dell Inspiron B130 Notebook
Laptop Key repair
Sound like you need to replace the whole keyboard. You can just buy a replacement keyboard from Dell and replace it yourself. The keyboard is a whole piece that can be removed buy removing the screws from the bottom of the notebook. Best Buy will charge you lot to do this.
Please rate response.
Feb 17, 2009 | Dell XPS M1530 Notebook
Dell Inspiron B130 Notebook Logo
249 people viewed this question
Alun Cox
