Cameras Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camer is saying memory card is locked, and it isn't
Anonymous
Level 3:
  • Master 747 Answers
  • Posted on Jan 14, 2011
Anonymous
Master
Level 3:
Answers
747
Questions
0
Helped
177252
Points
2087
I'm going to give you a diagram to show the correct position of the SD or SDHC memory card lock.
Also the error will show if you haven't formatted the memory card Formatting is generally in your camera set up menu. You didn't say what make or model so i can't assist with this infomration all I can do is suggest you go into the camera set up and scroll through down through the menu to find format or your camera may call it initialize.
Diagram
Says memory card protected when I try to use it
If card lock button isn't faulty and doesn't free by sliding it a few times does your camera have a memory lock function in the menu?
2helpful
2answers
I cannot delete photos from my camera it says
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Memory Stick Duo 512MB. Where are no pictures on the card, but it says that "were is no space" when I put it in the camera. What should I do?
First make sure the card is not locked. Do this by checking on the side of the card that the lock notch is not in the locked position. If it is not locked then you should put the card in your computer and reformat it. If this isn't successful then its time to go get a new card. You can get a new one for under $20.
10helpful
WHEN I INSERT MY MEMORY CARD IN MY SONY CYBERSHOT DSC W510 IT SAYS MEMORY CARD LOCK.....HOW CAN I UNLOCK THIS ?
Hello there And Welcome to Fixya !
First of all there isn't any problem with your memory card or camera .
Take out the memory card from your camera and take a look at memory card , there will be a lock pin on the memory card .just unlock it with your finger cause it has a tiny knob
Do comment if it helps you in any manner
When i turn on my camers it says memory card locked
Hi there, Some memory cards have a very little (like a button) type of plastic on one side of the card, which can move (slides across). At one position its locked & at the other its unlocked.
Hope this helps. ****.
2helpful
Says memory card locked-it is not -the card works fine in other camers
What type of memory card are you using? If you have an SDHC (high capacity SD) card, it will not work with this model. This model came out before the SDHC protocol was developed. You can use an SD card, maximum 2GB, or MMC card.
26helpful
2answers
Lumix dmc fs3 troubleshooting - memory card is locked
Take the card out - on the side there is a little white slider with a locked & unlocked padlock symbol - move it to the opposite position it is in now.
2answers
Memory card protected why?
Take out your memory card and see if there is a switch on it. Move the switch to unlock.
Brand new memory card not accepted
new memory card not will go in card error and lock
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
