My Bosch dishwasher model #SHU43C05UC/14 drains well and has enough water(I replaced the inlet water valve already),but not washing the dishes clean especially the top rack.What could be wrong?
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
my program 2000 dishwasher is beeping and not working correctly the light flashes 4 times and then...
(More)
my program 2000 dishwasher is beeping and not working correctly the light flashes 4 times and then pauses please help me
Maytag MDB6000AWB runs OK, but the sequence of cycles is off. When it finishes washing it doesn't...
(More)
Maytag MDB6000AWB runs OK, but the sequence of cycles is off. When it finishes washing it doesn't drain. To drain the selector must be moved to start, and then it will drain. Any suggestions would be appreciated.
