Question about Garmin GPS
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot with my computer cable
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Posted on Jul 14, 2008
Garmin Street pilot C340 has always worked. This morning it did not turn on. I relpaced the fuse in cord. Any other ideas?
Try charging it from the WALL charger. The battery inside the unit may not be too great. Try it - over night from the WALL charge -not the PC charger. 8de415c.jpg
May 04, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin 340 street pilot
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
Mar 29, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin Street Pilot c340 does not turn on
try calling Garmin and ask their tech department for help or go to their web site and explain problem they should get back to you right away.
Oct 03, 2017 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 Street Pilot
I had the same problem. Found out that the fuse had blown in the power cord. I bought a new fuse from radio shack and have not had the low battery since.
Mar 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin Street Pilot c340 mount
Try a hard reset using the reset button under the silver trim on the front. Pull off the trim ring by hooking your fingernail under it right below the logo.
If that doesn't work, then take the unit off of the mount for a better look at the contacts. Re-seat the mount onto the unit and see if that helped. If the mount is damaged, consider getting a friction mount instead of the suction cup. For about $40 you'd get new power contacts and a new cord, and the unit would sit on your dash instead of falling off the windshield all the time.
All of this is assuming that the problem occurred suddenly after a fall, and that your battery is still good.
Oct 13, 2008 | Garmin StreetPilot c340 GPS Receiver
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get teh unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jul 12, 2008 | Garmin StreetPilot c340 GPS Receiver
Pin problem
This is ODD, because I don't believe the C240 has a PIN lock.
However, have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jul 01, 2008 | Garmin StreetPilot c340 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
212 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
