Printers
Problem for Printers
Generic problem for all Printers
1020 PRINTER DRIVER HP
By SANJEET_jj on Jul 14, 2008
I CANT FIND HP 1020 DRIVER FOR VISTA
Same Problem
Mar 09, 2009
-   hplaserjet1020 driver find and send me-   zarehman786
Jan 15, 2009
-   yes I have the same problem
-   Guest
Solution #1
posted on Jul 14, 2008
Not Rated)
Ekse
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 4719 votes
There are no drivers for fixya but I have found a workaround by some anonymous poster
Xp software&drivers will work in Vista after a little tweaking in printer properties.
1)Install the CD-Rom HP Software/Drivers that came with your Printer at the time you purchased it. These Xp software&drivers are Vista Compatible after tweaking the Printer Properties. Reboot after installing.
2)Goto Start/Printers. Right click HPLaserJet1020 then Left click Properties. An HPLaserJet Properties window should have popped up.
3)Click the Advanced Tab. Click the Print Processor button located at bottom of window.
4)Select print processor as>>>IMFPrint. Then Select Default Data Type as>>>RAW. Click OK.
5)Now return to the Main HPLaserJet Properties window and click the General Tab. On the Bottom of that window; Click the Print Test Page Button. Finished! A test page should be printing out if you adjusted the printer properties correctly. Enjoy!
optionally you may have to disable print spooling
Quote "This did not work for me until I changed the option in that same window (advanced settings) to "print directly to the printer". Spooling does not work. "
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
MP 620 printer is it a good buy
Answer
konika minolta 1600 magicolor
Answer
i would like to clean the ink cartridge of my printer because everytime I print pictures it always... (More)
Answer
i am trying to print heavy stock christmas cards on an hp j4550- - but i get a paper jam every time.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
