Question about Toshiba Satellite A100-S8111TD Notebook
I can't enter the start up...
Sorry, I'm a newbie in using computers and laptop, my laptop just continue to finish the setup, however in never ends, when the loading reaches the end of the line, a problem pops up then reboot automatically the system and the setup, and i can't even get into the password access...
the setup ends with this message:
A problem has been detected and windows has been shut down to prevent damage to your computer.
PAGE_FAULT_IN_NONPAGED_AREA
If this is the first time you've seen this error screen, restart your computer. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed software or hardware. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Advanced Startup options, and then select Safe Mode.
Technical Info:
***STOP: 0x00000050 (0xF7BEBOOC, 0x00000000, 0x05D8350, 0x00000000)
*** atiide2k.sys - Address F7BEB00C base at F7BEA000, DateStamp 40bf6f34
Beginning dump of the physical memory
Physical memory dump complete
Contact your system administrator or technical support group for further assistance.
That's All... Hope you can bear with me, thanks.
  • 476 Answers
How was the reinstall administered,from the hard drive restore image or from the disk?
Reinstalls can be for a few different reasons,ie,virsus you cant get rid off or failed drive that has been replaced with a new one and needs a new install of an Operating system before you can use it..
Statring with a fresh install on any computer seems a fail safe way to establish a solid base foundation and a good stable system.
Good ram will help speed thru the processes,faster the better I say,Don't forget the SP2 updates so the devices will function correctly with the right instructions etc...
Lastly,If install was from the original disks and there are still the faults present you may have to return the unit to the manufacturer for a service agent to reinstall,
Posted on Jul 14, 2008
  • Verne Koti Jul 14, 2008
    Possible hardware failure,replace component and start again
System setup screen
when you first start your computer and the screen is black a prompt will in the upper screen will tell you to hit f1 or f2 to enter setup. If you miss it or dont see it let windows finish loading then restart your computer and hit f1 and f2 several times right away and it should enter the setup or cmos page.
Nov 03, 2013 | Computers & Internet
Tip
Installing Windows XP
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Every one who owns a computer should maintain it on their own from time to time.
Reinstalling your Operating System is one of the methods of computer maintenance, and is a bit complex.
With these steps, you will successfully install Windows XP into your computer.
These steps are similar to other Windows OS installations (Vista, Windows 7).
Below is the detailed procedure of installing Microsoft Windows XP:
  • Before installing Windows XP or any other operating system, you should backup all your data. Data can be backed up on a separate partition, if the hard disk is partitioned or you can back it up on external storage devices like CDs or on a network.
  • Restart the computer and go to the Setup menu by pressing F2 and change the first boot device to CD, press Esc and save settings.
  • Insert the CD labeled Microsoft Windows XP into the computer and restart the computer.
  • When the pc restarts, a message will appear telling you to press any key to boot from CD, press a key immediately the message appears and the setup process will begin.
  • After the files have been loaded, Windows will start and it will give you an option of repairing using Recovery Console by pressing “R” or continue with setup by pressing “ENTER”; press enter to continue with setup.
  • Setup will list all your disk partitions, highlight the partition where you want to install Windows, this is mainly partition “C”, press “D” to delete the partition, then press “L” to confirm.
  • Highlight the partition you deleted, and then press “C” to create a new partition, press “ENTER” to create the partition.
  • Press “ENTER” again to install Windows on the New (Raw) Partition you have created.
  • Format the partition using NTFS file system.
  • After format has completed, Windows will restart and setup will prompt you to boot from CD again. Ignore the message and let setup continue automatically.
  • Follow the next steps which will ask you to setup the system Time and Date, Network and enter a serial key, until setup finishes.
  • After setup has finished, Windows will restart and will welcome you for the first time; Microsoft Windows XP will have successfully been installed on your computer.
on Jan 07, 2010 | Computers & Internet
Resized c drive, now windows won't start. How can I reinstall windows from windows disc
Hi Terrez,
  1. To reinstall windows from Windows disk Insert the disk in the drive, restart the computer and enter the BIOS setup.
  2. In BIOS setup, make the DVD Drive the first-starting device.
  3. Save and exit BIOS setup.
  4. Now the computer continues the restart. Look at the screen. When a message appears, you have only a few seconds to hit any key on the keyboard in orter to start the computer from the disk.
  5. From there, Windows setup will continue.
Feb 24, 2013 | Acer Aspire 3680-2682 Notebook
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
Windows is corrupted
If your Windows is XP then try REPAIR Windows if the laptop cannot boot up.
1. Insert your Windows XP Install CD into your CD-ROM drive.
2. Boot up your computer with the Windows CD.
3. Run the SETUP go through the first part of the Installation procedure.
4. When the "Welcome to Setup." press Enter to Setup Windows XP.
5. Press F8 to agree to the End User License.
6. Let Setup search your system for previous versions of Windows.
8. When Setup is finished searching your system, select your Windows XPInstallation and press the R key on your keyboard to start the RepairProcedure.
Setup will replace all major system file.
After Windows has been REPAIRED then do a Windows update to install the latestupdates on your computer.
If this did not work the you need to Install Windows again and not try to REPAIR Windows. Then install the laptop's device drivers and your programs.
Apr 17, 2011 | Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
How to uninstall deep freeze 6?
You havent mentioned the O/S you are using, try this if its XP
Here the small tricks to disable or unintal Deep Freeze ver 6 without password:
  1. Boot your computer from Windows XP Installer
  2. After appear “Enter to Setup” option, Press Enter then press F8.
  3. Selected R to repair Windows system ( Repair Setup)
  4. Continue repairing/installing windows untill finish.
  5. Prepare the Deepfreeze v.6 installed, open the file like you want to install the software.
  6. it’s will show “Uninstall Deep-freeze” options. Uninstall the software, after uninstall finished reboot your computer.
  7. Now the Deep-freeze has removed from your computer.
FOR VISTA / WIN 7
Power Off the PC
Start the PC and Press F8 key till you get Boot options,
Start the PC is SAFE MODE and try to uninstall it.
Jul 06, 2010 | Computers & Internet
Os keep restarting. on boothing the laptop, the windows starts and the user interface loads. when ask for username and password, on entering the username and password, the laptop restarts.
From my point of view I think the Operating system needs to be Repaired and below is a guide on how to repair
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press ENTER to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R", (you DO NOT want to load Recovery Console). I repeat, DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read WARNINNG #2
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. After the installation is over the system will reboot.
Enjoy
If This Solution has Worked Please RATE ME!!!!!!!!!!!!!!!!!!!!
Oct 22, 2008 | HP Compaq Presario 2200 Notebook
My laptop is not switching on
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
Oct 22, 2008 | Toshiba Computers & Internet
Uninstall the deepfreeze in vista
  • Booting Computer From CD use Windows XP Installer
  • After coming up with part to Enter Setup, Press Enter then F8 and await some moment
  • then selected R to repair Windows ( Repair Setup)
  • Hereinafter continue Install windows untill finish.
    1. Now prepare the Deepfreeze v.6 of and double click
    2. will appear “Uninstall Deepfreeze” windows and process uninstall till finish.
    3. Done……
  • In this time i still not known more effective way to remove DeepFreeze 6.0. if there is a way of more effective please share here… icon_biggrin.gif
  • Jul 25, 2008 | Microsoft Windows Vista Ultimate Edition
    Toshiba Satellite A100-S8111TD Notebook Logo
    289 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
