Hard Disk is giving the sound after start. - Computers & Internet
  • 51 Answers
If your hard disk runs perfectly with sound,there will be no problem.But if with some sound u are facing poblems,then u may want to replace it soon.Check waranty also,because most of the hard disk are coming with 5 years waranty.no worry please.
Posted on Jul 14, 2008
My lappy hard disk is giving status that hard disk failure try to install in other location. then i connected it to my pc to take backup
Not sure I understand your Question... or maybe you are making a statement? But, it sounds like your hard drive (HD) is dead, no good , non useable... So what are your options? Purchase another hard drive, you should have received system backup disk or install disk with your laptop , you can use them to reinstall the operating system (OS) Windows on the new hard drive. There is a slight possibility you could try them (the install disk) to re-install your OS on your original HD, but again it sounds like your HD is dead.
If you have never made a back up of you hard Drive, then all your data (pic, documents, game, contacts) are lost. The problem most people don't understand is if the hard drive crashes for physical reasons, the spring breaks inside, or a diode burns out, then the data on the disk are lost.
You may also take your laptop to a computer repair shop near you and they can tell you more about your options.
Jun 25, 2015 | Hard Computers & Internet
PXE-E61: MEDIA TEST FAILuRE, CHECK CABLE PXE-M0F: EXITING NVIDIA BOOT AGENT. REBOOT AND SELECT PROPER BOOT DEVICE
Hope this helps. I assume cable is good, try to listen by drawing your ear nearer to the disk. The normal sound of the harddisk as the disk spindle comes to work when given power, a uniform thin sound of rotating motor. The abnormal rotations sounds like initializing motor-kicking and died down in cycle or it gives audible clicking sound due to arm-head drive coil initialization failure, it may also give a scratching sound when the tiny head crashed against the disk. By then, this audible signs gives us hint that the harddisk has a fatal error. However you can try another good cable, attaching it to another sata port, power connector and trying it to run on another pc. Hope it gives good signs that your disk is alive.
Mar 08, 2014 | Seagate Technology Barracuda 720012...
My emachine e728 laptop gives an error that it cannot start automatically when i turn it on.
Sorry to hear about your PC problems.
Sounds like your hard drive has gone south.
If you have a emergency boot disk or another hard drive to try ?
hope this helps
Nov 24, 2013 | eMachines E528 E728 Intel Laptop...
I have a problem with my m/b k7som+ 7.5c. When I press the pwr button everything seems ok, all fans are working properly and I also hear the HDD spinning sound. However there is no POST beep or anything...
There are a few procedures you can possibly try before replacing components.
I HIGHLY recommend you unplug power while trying these steps
1) Unplug power and remove CMOS battery (usually a small silver circular battery) on motherboard for 1 minuted then reinstall battery and see if it boots up.
2) Re-seat all RAM memory chips. If it doesn't help, then try booting the system 1 memory chip at a time, to rule out a bad stick of RAM
3) If you have a separate video card (not onboard video) then try re-seating it
4) unplug both data and power cables to all internal components (hard drives, CD-Roms, Floppies, etc) and also internal cards and see if it boots. If it does then reconnect one device at a time til you find the culprit
That's pretty much all you can do without swapping out parts.
I hope this help and I wish you luck!!
Regards
Mar 07, 2011 | EliteGroup V7.5A (K7SOM+ V7.5A)...
My hard disk give noise sound and disk not found massege is coming
Any (small) 40GB disk-drive is "out-of-warranty".
So, your disk-drive has "died". Replace it, and reinstall Windows.
Jan 19, 2011 | Seagate (ST9402113A) 40 GB ATA-100 Hard...
My laptop Dell Inspiron 1545 giving a hard disk drive error. Laptop works normal but sometimes it start producing a sound like tik,tik,tik......... then blue screen appears and when i run diagnostic it...
Its time you backup your data and contact Dell to get your hard drive replaced (in case your computer is in warranty) else order for a new hard drive compatible with your computer.
You will need your Windows CD that came with your computer, if you did not get it contact Dell about the same.
Dec 25, 2010 | Computers & Internet
Please give me solution for the hard disk error [ E 602 - 001, 002 ,003 ] in canon ir 8500 . i need the full suport of this problem
The wiring is faulty (short circuit, open circuit, disconnection). The installed
system file is faulty. The hard disk drive is faulty. The main controller
PCB is faulty.
Condition
0001 A fault is detected in the mounting of the hard disk when the system
on the hard disk is started up using the BOOT ROM.
0002 The appropriate system file cannot be found on the hard disk when
the system on the hard disk is started using the BOOT ROM.
0003 A sector error occurs on the hard disk when the system on the hard
Nov 15, 2010 | Canon imageRUNNER 8500 Copier
Not detecting
Sounds like a loose power cord...
-Damian
Jan 22, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
