  • Anonymous Jul 15, 2008
    When I try to change the radio station the cd player comes on
Buy another one.
Posted on Aug 05, 2008
I am having the same with NS-DA1902. Tried everything - cleaning, changing discs, calling Customer Service (joke). Ready to replace this less-than-yr.-old unit but WITH WHAT??
Posted on Jul 21, 2008
Hi, I have a Samsung Blue Ray home cinema system. When playing a Blue Ray disk it freezes after about an hour and a half. DVD's seem to play no problem. Have tried a cleaning disk but has not
Hi, if your sure it stops in the same time on any disc then i would assume there is something stopping the laser from moving forward.
If your confident opening it things may be obvious, KEEP HANDS AWAY FROM THE MAINS COMING IN.
The laser runs on two metal bars but all the gears are plastic up to the motor. The motor does'nt spin but turns in small movements as the laser reads in front, sometimes the teeth on the gears get clogged up. Let me know how you get on.
Jan 05, 2015 | Samsung Televison & Video
Why does it read bad disk? i've tried two disks, that work perfectly on another DVD player. But reads as Bad disk on the GPX D2816
its the disk laser sensor is to sensetive that why it canot reads with an ordinary disk or a pirated disk or a disk that has a small scratch.
Nov 07, 2009 | GPX D2816 DVD Player
Readable DVD's but not CD's
That is a faulty lens. The lens reads DVD and CD on different laser beam frequencies. To read the TOC initial track the lens must focus on the laser beam reflected by the disk. If the lens is opaque, scratched or dirty, sometimes it can focus on DVD but not on CDs or the opposite.
Try using a cleaner disk, if that does not work buy a replacement drive. Today you can get a dual layer DVD RW for less than $30.
Sep 25, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Dvds read bad
Get a laser cleaning disk and let it run in the dvd player for a few minutes then try playing a dvd. Its probably playing bad because the laser is dirty
Sep 21, 2009 | Toshiba SD-3980 DVD Player
My Toshiba SD-2715 dvd player periodically stops playing and turns off. This usually occurs after 1 hour of play. This has happened with multiple disks, and I have tried cleaning them with no improvement....
Try cleaning the lens, also the inside of the player in and around the disk tray is probably full of dirt, dust etc, carefully try cleanig all that out, you may need to disassemble a bit to get at everything
Aug 22, 2009 | Televison & Video
In SONY CD/DVD Player, it is able to read CD where as DVD is not able to be read. Saying NO disc. What could be possible reason and remedy for the same.
Some dvd have a multiple laser function for dvd and use a single laser for cd. common fault on not reading dvd is dirt on laser or fault on multiple laser that cannot read dvd. If cleaning doesnt help only repair tech can fix. Just check that the dvd is working in another dvd player to ensure it is not disk
Aug 14, 2009 | Sony Televison & Video
Will not play dvd's... get error message no disk... wrong disk ... tried multiple disk
Is this a cheaper-budget brand player? If so it could simple be a dead laser. The old cheap apex player were prone to that. They only cheap solution is to try a dvd laser cleaner. Possible accumulated dust etc is on the eye. Other than that it is probably best to pick up a new player. It's a throw away world these days.
Jul 08, 2009 | Cyberhome CH-DVD 300 DVD Player
Unfortunately that means the laser is weak or dead. It deads repair.
Aug 18, 2008 | Televison & Video
No read
The DVD-RAM Disk had trouble afeter Multiple recordings or any scratches. Buy a new DVD-RAM Disk and Try using that.
Feb 19, 2008 | Panasonic DMR-E50 DVD Recorder
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
139 people viewed this question
