Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Red color problem
Could I please have the PDF file to reinitialize the memory in order to solve the red color problem for the Hitachi 50V500? Thank you!
DID NOT FOR ME!
Posted on Sep 12, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Select a non-used or blank Video input or tuner to get into I2C menu, also make sure the Power LED on the Front of the set is not blinking at all.
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button.
  3. Then press the POWER button for two seconds.
    1. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
    2. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
    3. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
    4. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
    5. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
    6. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
    7. Turn the set off-on and Confirm the picture remains in a good condition.
      BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Jul 15, 2008
My Hitachi 50V500A has a large area where the color is turning out to red. Is this a lamp or a complete light engine replacement job?
not the lamp. hitachi knowingly had a defect with the fan not allowing enough air to cool the lamp which has burned the red color lense resulting in the red on your screen. enjoy your new brick thanks to hitachi!
Jan 09, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Red screen
The only solution is to replace the two STK Ic's on the board and your problem will be solved.Get it fixed by a repairman
You can get the parts at www.ptscorp.com or www.partstore.com
Hope ur problem gets solve soon..
Goodluck,
Please don't forget to rate me as fixya..
Feb 07, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red glow in Hitachi 50v500 television
Tv have a problems know as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts must be replaced on the tv convergence board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
It appears my hitachi 50v500 has lost its green? sharpness is still there but color has go amuck. what can it be?
Symptom: Picture is pink, not enough green, too red, redissh picture, shiny red picture, etc, permanent condition.
Cause: Please do Memory Initialization
Jan 05, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Red Smudge
That is the LCD version. I highly recommend a professional do that work.
Jul 14, 2009 | Hitachi Televison & Video
Red in Color Shadow
contact authorized servicer to do a memory initialization in the service mode
Apr 02, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Light Engine Problem with my Hitachi 50v500 - Solution
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
Aug 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
The color is low
If this is a 50V500 record the I2c buss settings then "Memory Inti" then re-write the recorded data. Solves about 80% of the color distortion problems. If it's not a 50V500 you need to expound on your problem and include the model number.
Bill
Mar 24, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500
Email me privately and I'll send you the asc data sheet directly from Hitachi... Make sure to give me enough information about this to jog my elderly memory - I get between 3-5 thousand emails a day...
Bill
Premium Technologies
premtech@willapabay.org
Nov 15, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Pink Screen
There is a service bulletin for this problem - you need to reintialize the memory settings in the service menu - I have a pdf file showing how to do this.
Sep 09, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
440 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
