Question about Canon PIXMA iP2000 InkJet Printer
No ink impresion after cleaning the waste in pads....
Hi...
Thanks for the suggestions of cleaning the waste ink container but i'm sorry to say that now only the paper feeds but there is no ink impression on it i've tried replacing the cartages but without any success
Please let me know if there is something I have done wrong and also if there is any particular path the drain tubes have to take through the white compression cylinder before draining....
thanks
chris
  • 4,041 Answers
Hope it will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
Can you give me a wicreset keys for epsonL210
Is the waste pad full ?
If the waste pad is actually full and ink is about to overflow, then you need to install a waste container. You can see the waste pad by opening the access panel on the back of the printer.
Changing the waste pad requires almost complete disassembly of the printer, it is a big job. There is an easier way.
Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coathanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won't come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Now the ink will go into this container and not into the waste pad inside the printer. If it gets full, dump it.
Note: This information and a couple of photos are also available on Steve's Digicam Forum (http://stevesforums.com/forums). Goto Printers-Photo Inkjet-Epson R200-210 & R300-310 Mod
Nov 09, 2014 | Epson Stylus Photo 2100 InkJet Printer
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
How do I remove and clean the waste ink pad on my Epson R200...where is it ? and do I have to remove the ink cartridges before I do it ? If so do they reset themselves afterwards? Thanks, Pauline
1. Press and hold "Stop", "Maintenance", and"Power" buttons for about 10 seconds. A message will comeon the screen saying counter is reset and to turn the printer off. TheR200 and others don't have a screen so just wait until the 10 seconds isup. 2. Turn the printer off, unplug the power cord. Wait about 1minute and power the printer back up. The counter will bereset. That's all there is to the reset procedure. 3. The waste padis actually full and ink is about to overflow, then you need to install a wastecontainer. You can see the waste pad by opening the access panel onthe back of the printer. Changing thewaste pad requires almost complete disassembly of the printer, it is a bigjob. There is an easier way. Open the access panel on the rear of theprinter (remove screw) and look inside carefully with a flashlight. You will see a tube (down and to your left) coming from the cleaning pumpand it will have an open end on it. This is the tube that delivers ink tothe waste pad. Use a piece of coat hanger wire or equivalent, and fish out thispiece of tube. Bring it to the outside of the printer, thru the accesspanel. Find yourself a suitable container (Tupperware or a plastic cup or jar)that is not too tall. Put the tube into this container and secure thetube and container so they won't come apart or lose connection if the printeris moved. If you wish you can make a hole or notch in the access panel cover soit can be replaced. Now the ink will go into this container and not into thewaste pad inside the printer. If it gets full, dump it.csts_0.jpg
May 18, 2011 | Epson Stylus Photo R300 InkJet Printer
Received message ''the waste ink absorber is full'' What can I do?
You will have to replace the waste ink pads. There should be two of them on the right under the print head in rubber containers. It could be a messy job though. I think the pads on that printer has a metallic strip for detecting full condition. So you can't reuse the pads even if you clean them up.
Sep 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Re.ink pad
Waste Ink Pads. They need to be cleaned/replaced and the counter reset. Look at the Ink Waste Container kits here. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
C46 printer
I could not find the manual, but I hope this helps:
I'm not sure if the waste ink pads are in the same place as the c45, but i hope this helps.
Locating the waste ink pads was pretty easy. First of all you have to dissasemble the case, then remove the paper slot. To do this you have to unscrew three or four screws (at least in my c45) that keep the paper slot attached to the printer. After doing this you will see the ink pads, they are at the bottom back of the printer. Mine has four of them with an "L" alike shape.
Clean them with plain water, then let them dry a couple of hours until all the moisture is gone.
I advice you to remove both ink cartidges before doing this because an strange thing happened to me.
After removing the ink pads i cleaned the ink pad container (you'll see the little tube that drains the "waste" ink from the cartidges to the pads) then a couple of hours later i found that the container was full of ink!! confused1.gif . And of course, the ink cartidges were almost empty upset.gif
That happened because i didn't remove the ink cartidges before doing the whole process. I have no idea why that happened but probably by removing them you'll avoid that.
Epson resetter software can be found at http://www.ssclg.com/epsone.shtml (the link to download it is located at the bottom of the page)
One last thing, to reset the waste ink counter you have to go to "Protection Counter" menu and then click "Reset Protection Counter".
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
Changing waste pads
try this rescue kit that includes everything you need to do the job, including how to clean the old pads instead of buying new ones.
http://www.tradebit.com/filedetail.php/2379162-Documents-eBooks-Technical
Jan 08, 2008 | Epson Stylus CX6600 All-In-One InkJet...
How do you remove the waste ink absorber pads?
all above suggestion and solution are okey/
After opening printer best way to clean it that your hand not getting dirty wear rubberize gloves take some old injectable cyrin, suck it put into container with fine screen filter/ nothing left ink ,injection cyrin connot suck anymore .replace the pad if available or clean it /soak w/detergent wash and dry..
Jan 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
R300 ink Pads
http://www.stevesforums.com/forums/view_topic.php?id=51595&forum_id=40&highlight=R300+container
Sep 13, 2007 | Epson Stylus Photo R300 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
43 people viewed this question
old marine
old marine
Corne Viljoen
