Question about E-Machines (308714) Motherboard
Emachine doesnt turn on
I have an emachine desktop and when i press the power button, i get nothing. No lights or fans turn on. I replaced the power supply and i still get nothing.
  • 2 more comments
  • Anonymous Jul 26, 2008
    yo i got the same problem any solutions??
  • Brian Vogler
    Brian Vogler Aug 01, 2008
    Same problem with a model T2984. Suspected surge through power supply. Replaced PS but still no power to MB. I would assume processor and memory also damaged.
  • Anonymous Aug 03, 2008
    I also have the same problem or sympton..
  • fancool Aug 18, 2008
    When pressing power button nothing happens on my e machines 530 desktop pc.Power lead is providingf 240 v ac.Please can you help me?
    Problem Solver:
  • 3 Answers
My emachine did the same until I replace the hard drive now it turns on boots normal but won't load windows completely.
Posted on Oct 11, 2008
    Scholar:
  • 172 Answers
Contact me for support on these computers free of charge at compdoctor2005@btinternet.com
Chris
Posted on Sep 15, 2008
  • Chris Fell
    Chris Fell Sep 15, 2008
    An emachine with random shutdowns, or no display on screen is caused by motherboard failure. These emachines, suffer with problem motherboards, giving the impression that the power supply has blow. When the pwer supply is replaced, the pc still fails to boot althought the pc can be heard to be active, i.e the cpu cooling fan is runnin, the cd and hard drive can be heard to be active, but there is no dispaly on screen. This is caused by a motherboard failure, it is this problem which blows the power supply not the otherway round!! Contact me for support on these computers at compdoctor2005@btinternet.com
    The same problem exist with Advent,Medion,Packard Bell, Compaq and EiSystem computers. i am and expert on these computers.
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
EMachine 2862 Desktop Dead On Power-Up
check all the leads to the hard drive and check that the fan starts spinning when you switch it on if it dont start then the problem is the switch these do often go and can be easily replaced and they are not expensive i had the same problem and found that it was just the switch hope this solves your problem for you you can bypass the swith so that the computer comes on when you turn the plug on but when you shut down the computer this shuts everything down but the switches are cheap enough to buy if you have changed the power pack then the only thing it can be is switch .................................
Oct 31, 2007 | E-Machines T2682 (000002965) PC Desktop
I have a emachines t2984 i press the power button and doesnt turn on i replaced the power supply with different ones and nothing and the light turns on (power button) but the when i press the button the...
Ok, test the power button pins. First disconnect any power source to the computer. Then, find the power pins on your motherboard (the one that your case's power button connects to. Usually two wires, one red and the other black). Grab a jumper a connect it to those two pins, they usually have the letters "pwr" or "power" printed next to them. Then, once you've done this, with the jumper connected, connect the power cord to your power supply. It should turn on by it self. If it does, then the problem is the power button. If it does not do it, then the problem is the motherboard. Good luck.
Jan 22, 2010 | E-Machines eMachines Refurbished EMA...
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Yellow Light
Emachines are bad for having failed power supplies and motherboards. Test your power supply, watch this video.
http://www.metacafe.com/watch/729606/how_to_test_your_computers_power_supply_psu/
Aug 03, 2009 | E-Machines eMachines Desktop PC
Battery light flashes but know power
Is there any video at all? If there is no video, it could be CPU, memory, MB. IF there is video, it could be hard drive, memory.
Aug 02, 2009 | E-Machines eMachines Desktop PC
Wont boot/start
Turn off power, unplug, hold power button for 30 seconds, take out memory, or if you have more than one stick only take all but 1, plug the power back in and start the computer. If a screen pops up that bios has changed press F2 to continue once computer is completly loaded click start, shut sown, unplug power cord again, hold power button 30 seconds, insert other memory and restart
May 13, 2009 | E-Machines eMachines Desktop PC
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Emachines 5210
Can you hear fan inside the PC? Any flashing lights next to the power button? Please give us more details.
Oct 23, 2007 | E-Machines eMachines Desktop PC
E-Machines (308714) Motherboard Logo
272 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
