Question about Sony PlayStation 2 (PS2) Console
Disk doesn't rotate when the "eye" is reading.
I checked the whole wiring and have continuity.
  • carlosperez Jul 16, 2008
    My power supply output is 8.5V and that is OK. I guess I have a problem in the motherboard. All the flexible wires have continuity and the laser beam is working. I need to know what is the voltage that the motor needs to start to spin the disk.
  • valah Jul 16, 2008
    My disks are not rotating. Can this be fixed. How?
First you checked the motor insde it and check the dvd is comptable with ps2 or not and tell me what about your power supply due to less power it does not work properly ok
Posted on Jul 14, 2008
Replaced rear brakes for disk breaks on 2006 chevy 1500 lights comes on abs
check to see that the sensor wires that sense axle rotation are connected. Some are near the caliphers abd read the rotor rotation and in my car with rear drum brakes it is in the axle housing next to the axle bearing. Check that the sensor is compatable for the new application
Jan 14, 2013 | 2006 Chevrolet Silverado 1500 2WD
Rotate screen back to horizotal
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation.
or
Press "Ctrl-Alt" and an arrow key (left, right, up or down) to rotate the screen.
Continue pressing the hotkeys and arrow keys until you reach the desired rotation. This works with most video drivers on Windows XP. If it doesn't,
Click "Start," then "Control Panel," then "Display," then the "Settings" tab. Click the "Advanced" button. Check for an "Orientation" option. Select your desired orientation.
hope this helps
Jul 25, 2012 | HP Pavilion tx1000z Notebook
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
I have a 95 impala ss, i have a brand new opti-spark, plugs and wires. they were changed 2 wks ago. this morning when i started it, it ran rough, then when i patted the gas pedal it hesitated then it would...
What type engine? I assume if it is opti-spark it is a v8. L type .Check the routing of wires. GM vehicles are very susceptible to cross fire . Opti-spark distributors are notorious for failure as timing is achieved by a laser eye reading slots of a rotating disk and sending that data to the pcm. It was GM biggest failure. Check the installation especially the cap. Voltage will fluctuate anytime and engine's timing or firing if not on point.
Sep 18, 2017 | 1995 Chevrolet Impala
Furuno 1715 gives "no heading pulse" error. Image normal, but clocked due to no reference. Pulled heading sensor (4X6X1mm black box, two wires, labeled NRS-101) and checked continuity across leads. Open...
Heading pulse is a reed switch sensor built inside the dome. upon each rotation of the array the reed switch is activated. Do a visual inspection of your array (inside) to make sure it is spinning (verify from a distance). Don't get eye level with the rotating array it can cause great harm to your eyes. Normally I have seen the belt slip off and also the lanyard attachment get caught in the array. Check those two things as well.
Mar 06, 2010 | Furuno 1715 LCD Radar System GPS Receiver
GE JSP39 range; front right burner eye doesn't work at all
there are two tests to chk which is bad,wether it is the control switch or the elemnt.disconnect the power to stove and open the top and disonnect the wires from elemnt and chks the continuity of the elemnt coil with a multimeter.if the meter does not read continuity then elemnt is bad.to confirm this connect the wires back to the elemnt and plug the unit to power, turn on the switch to high position and read the voltage coming to elemnt.it should be 240 volts.if u read that voltage, then for sure element is bad.if every thing is opposite to this then it is the control switch which is bad.
Aug 21, 2009 | GE JBP65 Electric Kitchen Range
Emerson AV50 says ''NO DISK''
Hi, sounds like you have a dirty laser eye on the DVD player. The eye gets dirty and it won't read movies or function properly. I would recommend a DVD Cleaner CD. I would have you try this before I have you open the DVD Player to clean the Laser Manually. Please try this and Post the Result for me to Review. Thank you
May 19, 2009 | Emerson Audio Players & Recorders
Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Aug 31, 2007 | Daewoo DVDS151 DVD Player
Sony PlayStation 2 (PS2) Console Logo
24 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
