Question about Mitsubishi VS-50705 50" Rear Projection Television
Help please! when i turn on my tv its fine, 5minutes later the pictures starts like kind of bowing or jumping, then in like 5 or 10 minutes later its fine for the rest of the time its on
  • demonic66699 Oct 17, 2008
    is there a way you could explain the weak capacitor in the vertical defection circuit or solder joint to me so i could attempt to fix, cause man, its getting worse.
  • Mitsubishi Master
  • 8,617 Answers
Most likely a weak capacitor in the vertical deflection circuit or a solder joint.
Posted on Jul 14, 2008
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
May 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Flickering/jumping picture
I HAVE THE SAME PROBLEM. TV WAS FINE UNTIL A FEW MONTHS AGO. OF COURSE ITS OUT OF WARRANTY. FROM WHAT I HAVE READ, AND BEEN TOLD, IT IS THE POWER SUPPLY TO THE UNIT. IT IS DEFECTIVE, OR IT OVERHEATS AND TRIES TO SHUT DOWN. A LAW SUIT IS IN PROGRESS AGAINST WESTINGHOUSE TO RESOLVE THIS MATTER. KINDA REMINDS ME OF THE XBOX 360'S WHEN THEY CAME OUT. ALL YOU CAN DO IS TAKE IT IN FOR SERVICE. OR, YOU CAN KEEP TURNING IT ON AND OFF, LIKE I DO. I HAVE HAD THIS TV ON ALL NIGHT BEFORE WITH NO PROBLEMS. AS SOON AS I START CHANGING STATIONS, OUT IT GOES. GOOD LUCK. WESTINGHOUSE WILL NOT EVEN EMAIL ME. I HAVE TRIED SEVERAL TIMES TO CONTACT THEM. I HAVE HEARD FROM THE LAW FIRM IN CALIFORNIA THAT IS GOING AFTER THEM. GO ONLINE, AND JOIN THE CRUSADE.
Mar 25, 2009 | Westinghouse SK-32H240S Television
Jumping Screen
I've had a couple of these. The panel control board is going bad, but there may be a way to make it last a bit longer. If you go into the MENU of the TV, and turn off all the color correction, all the whistles and bells that come inside the tv to "make the picture better," it usually helps. Any kind of motion correction, or any kind of noise reduction (picture noise reduction) should be turned off. If the picture has a cloud of green pixels that seems to pepper the screen, then after you turn off all the stuff in the menu, unplug the TV for 5 minutes, and then plug back in. It should help the picture some.
Hope this helps...
Jan 05, 2009 | Insignia IS-LCDTV32 32 in. Television
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
TV Turning on and off, left side of picture is not lining up, bowed in center
Most likely you had a power surge issue that caused the tubes in your crt projection to malfunction. I would recommend having a service call done to find out the issue
Apr 22, 2008 | RCA P61960 61" Rear Projection Television
TV-Bowing
can you post a pic of your screen so i can properly diagnose the problem as it could be either a pincushion or convergence problem. A picture would clarify it for me.
Apr 16, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Tv needs fixing, advice appreciated
it would intermittedly display a bowed rainbow effect and the picture would jump to that/black/back into focus. it was nothing but due to change of place due to decaussing ckt to take care of magnetic effect of earth. this morning i turned it on with a black screen. It has audio but no video. your problem it sounds me that it is due to loose contact or loose connector or due to video ckt. as you said that sudio is ok. if you are not tech person call skilled tech to fix it .it is not a major problem. hope this will help you please let me know what happened.
Sep 29, 2007 | Toshiba TP50F60/61 TV
Mitsubishi VS-50705 50" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
