Question about Mitsubishi VS-50705 50" Rear Projection Television
Screwed when i turn this thing on, after a few minutes the picture starts to jump pretty bad. for like 5 to 10 minutes then it is fine for the rest of the time its on???????????????????????
  • Nic Schroeder Sep 30, 2008
    sorry, i just now saw your post. explain what exactly id be looking for. if those have a weak signal or something then replace them or what?
  • 927 Answers
Good Day, demonic69699;
Sorry you are having a problem with the TV, but this a very common problem this model. Please try this: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Good Luck, big IRISH.
Posted on Jul 17, 2008
1999 Jeep Cherokee Sport was working fine, then would not start this am, jumped it and it started ok, drove about a mile and battery voltage pegged to the right and check gauges light came on, brought it...
sounds like a regulator malfunction to me..need to connect a battery/alternator tester to the system and see if the regulator is bad.. this will cause full charge of the alternator to enter the system.. this uses the battery as a regulator and will cause overheating of wires and relays..if the alternator can be removed and tested separately(most can), do this and see if this is the case..replace if bad..good luck..
Jan 27, 2013 | 1999 Jeep Cherokee
98 Buick Regal won't run unless hooked for a jump.
you may have a bad ground, or the ignition switch needs to be replaced.
Jul 28, 2012 | 1998 Buick Regal
05 ford escape wont start. jump started it and it started fine but only runned for a few minutes and the engine started to stall and went off. tried to start it again and it wont turn with the same...
okay try this....talk to your parts store and get a battery load tester, and find out if the battery is indeed dead. My guess is it sounds like the Altenator is dying. they are around 50-100 and can be install by a pro in minutes.
Jun 16, 2009 | 2005 Ford Escape
Flickering/jumping picture
I HAVE THE SAME PROBLEM. TV WAS FINE UNTIL A FEW MONTHS AGO. OF COURSE ITS OUT OF WARRANTY. FROM WHAT I HAVE READ, AND BEEN TOLD, IT IS THE POWER SUPPLY TO THE UNIT. IT IS DEFECTIVE, OR IT OVERHEATS AND TRIES TO SHUT DOWN. A LAW SUIT IS IN PROGRESS AGAINST WESTINGHOUSE TO RESOLVE THIS MATTER. KINDA REMINDS ME OF THE XBOX 360'S WHEN THEY CAME OUT. ALL YOU CAN DO IS TAKE IT IN FOR SERVICE. OR, YOU CAN KEEP TURNING IT ON AND OFF, LIKE I DO. I HAVE HAD THIS TV ON ALL NIGHT BEFORE WITH NO PROBLEMS. AS SOON AS I START CHANGING STATIONS, OUT IT GOES. GOOD LUCK. WESTINGHOUSE WILL NOT EVEN EMAIL ME. I HAVE TRIED SEVERAL TIMES TO CONTACT THEM. I HAVE HEARD FROM THE LAW FIRM IN CALIFORNIA THAT IS GOING AFTER THEM. GO ONLINE, AND JOIN THE CRUSADE.
Mar 25, 2009 | Westinghouse SK-32H240S Television
Help please!
most likely a weak capacitor in the vertical deflection circuit or a solder joint.
Jul 14, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Picture flutter
As I indicated (I think) in another string, this sounds more like bad connections than anything else. Try resoldering the pins on the convergence ICs. Let me know if that does not resolve the problem.
Dan
May 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Jumping picture for a few minutes
theres a bad capacitor off the sweep power supply or possibly in the main power supply. Most likly though it would be where i mentioned first. There are no user serviceable parts inside this set Unless your a repair person so best thing for you to do is call in a pro to assist you in this repair. Good Luck
May 31, 2006 | Toshiba 50H72 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
172 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
