Looking for the driver for my NEC DVD-RW ND-1100A
  • 10,421 Answers
SOURCE:
Jumper setting in cpu
Not sure what the CPU has to do with anything! The following might help with CD/DVD drive jumper settings:
http://www.computershopper.com/storage/howto/installing-a-new-dvd-burner4
Jan 03, 2014 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Will not read any dvd
make sure the CD or DVD media you isnert is compatible for read/write opeartions
this DVD/RW is 12x40 trasnfer (rate read) and 4x16 write +RW
what format or speed CD media are you inserting ? go to this link to give you a better look at the specs of this NEC product you have
http://support.necam.com/optical/specs/nd-1100a.pdf
if this helped you , please rate me
Nov 03, 2010 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Stoped reading disk
the lens might probably be weak and the ROM might be old.Best solution is to replace it.
Aug 02, 2010 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
My dvd rw can't read dvd cd but they can read a cd only
try to go to registry editor and delete upper/ Lower filter. It should resolve the issue
Mar 24, 2010 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
What is the jumper setting as slave?
All drives are different, you have to look on your drive for the pin config
Nov 07, 2009 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
XP can't find ND-1100A drive
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 11, 2009 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
NEC DVD+RW ND-1100A
This is a single layer drive only. Usually dual layer drives have DL in the form factor so possibly a
NEC DVD+RW DL?
http://www.adamant.com/itemInfo.asp?GotoID=ITEM&PrdAbr=CDVN-3540A&menu=PARTS
Oct 24, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Nec dvd + rw nd-1100a
first try a audio CD see if ti reads that fine. then inset a data CD and see if you can see all the files on it. Try a few data and audio CD's. If it has trouble with any of these your drive has gone to the great garbage dump in the sky.
Jun 28, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Open Questions:
Computers & Internet Logo
60 people viewed this question
Ekse
Alun Cox
