Question about Dryers
My kenmore dryer has no heat - Dryers
  • MEBDRUMS Oct 28, 2008
    110.86983810 KENMORE DRYER NO HEAT.
    ELEMENT HAS CONTINUITY, REPLACED EARLIER THIS YEAR WHEN OUT BEFORE.
    THERMAL FUSE HAS CONTINUITY.
    WHATS NEXT?
  • 525 Answers
Your complaint is: "my kenmore dryer has no heat"
Based on the information provided above, I am unable to provide a positive solution to your issue. You have provided no model number! However, I have provided some common solutions to help guide you in your search.
This information is for an electric, generic model dryer only!
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Temperature Switch:
Make sure a positive heat selection has been made.
If your dryer still doesn't heat, check these:
Power from the house: Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element: Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse: On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring: A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 14, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Kenmore Dryer 300 Series No heat , I check continuity to all parts , it ok , but still no heat on dryer What's wrong?
What is the model number?
Exactly which parts did you check?
Also, check the breakers. The breakers are 220 and one of them may have thrown not allowing it to heat but the dryer will run.
Oct 17, 2012 | Kenmore 400 6942 Dryer
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Kenmore 70's dryer, not heating,
Maybe timer, try a different heat cycle.
Feb 06, 2010 | Kenmore Dryers
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore D433ele will not turn off...will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 31, 2009 | Kenmore 400 6942 Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Dryers Logo
317 people viewed this question
Top Dryers Experts
