Question about Microsoft Wireless Notebook Optical Mouse VSBX300008
Re: microsoft notebook reciever 1024
The optical receiver just stopped working all of a sudden. Purchased Driver detector for $29.99, but it did not solve the problem.
  • Anonymous Apr 24, 2009
    Mouse works fine for months, all of a sudden the Model 1024 Notebook Receiver USB plugin won't light up and mouse won't function.
The green LED on this reciever is also a button. Press the LED on the reciever with a small blunt object (pencil will work) and then press the "connect" button on the bottom of the mouse. The green LED should come on, and restore the connection between the reciever and the mouse.
Posted on Jun 03, 2009
  • 57 Answers
That was a waste of money. A new mouse would have been cheaper. If it suddently quit working the problem is probably hardwre related. Eliminate the usb port by plugging something else into that port and try the receiver in a different port.
do you have a ps2 adapter for it? If so this doesn't even require drivers in the first place if you use it.
Posted on Aug 04, 2008
Microsoft notebook receiver model 1024
issue? Check the battery, try syncing it using the connect button on the mouse, make sure the receiver is plugged into a working USB port.
Jan 03, 2012 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Notebook Optical Mouse 3000 is not working, reciever??
Your mouse is not sending any signal to receiver. Both items are working.
First look for a tiny thin button that protrudes from one of the sides where the receiver is placed in mouse, it might be stuck, push it gently down a couple of times, it has to be out for as long as the receiver is in the USB port.
If it still doesn't work, take the battery off, while holding down said button insert a new and fresh battery and then simultaneously release the button also considering that the battery terminals are clean. Hope you can solve your problem. Good luck!!! Chawah.
Jul 12, 2009 | Microsoft Wireless Notebook Optical Mouse...
Receiver not recognized by computer
Apr 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
I want to download a wireless mouse No. 1024
If you want to download a driver for a Microsoft wireless notebook mouse, go to one of the following locations:
http://www.mediafire.com/?sharekey=9144041283e5344bd2db6fb9a8902bda
http://www.microsoft.com/downloads/details.aspx?familyid=EA22BD62-4873-406A-BBBE-C587D35A53BF&displaylang=en
After you download the driver, run it and select which mouse you have.
Nov 18, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Mouse Wireless Model 1023/1024 won't work
try using an eraser on the contacts if you can reach them. Sounds like dirt/corrosion build-up.
Jun 15, 2008 | Microsoft Wireless Notebook Optical Mouse...
MS Wireless notebook mouse 4000
I have already broken two of them. It seems that the receiver is very sensitive to hits. Probably a PCB issue. I disassembled the receiver and discovered that if I bend it a little it starts working but if I leave it stops.
Jan 16, 2008 | Microsoft Wireless Optical Notebook Mouse...
My green light on the receiver is ON. The mouse battery is new. The red LASER switches with movement. I read all of the posts, than I pulled apart the receiver and the wires were OK. There is a micro-switch in the receiver, so I pushed it when plugged in to the computer. The green light flashes, then I pushed the button on the bottom of the mouse, it connects. To make short of this, do not open the receiver case, just use a pen and push the green "connect" light (must be in USB port), it will activate reset switch and blink. Next, push "connect" on the bottom of mouse.
Nov 27, 2007 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless notebook mouse model 1024 will not function.
I called microsoft and they could not fix the problem, stated it was a faulty device and are sending me a new one.
Oct 21, 2007 | Microsoft Wireless Optical Notebook Mouse...
Microsoft Wireless Notebook Optical Mouse VSBX300008 Logo
463 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
