Question about Hotpoint 24 in. HDA3700G Built-in Dishwasher
Smells bad The dishwasher has been smelling awful. We took the lower tray out, unscrewed the "trap" looking thing in the back right corner and there is standing water in the drain part and it stinks horribly.
I have a very bad smell in my elite kenmore diswasher. We have had it for a year now. I have been smelling this now for several weeks and I didn't know where the smell was coming from until this morning when I pulled the door down to unload my dishes.
Posted on Mar 11, 2009
My new Samsung dishwasher has a HORRIBLE smell
There are 2 possible explanations for this, either the dishwasher has a buildup of food particles and grease in the pipes and pumps and that is starting to decay. Get a dishwasher cleaner and run it through a cycle. You can find several different brands, Finish seems pretty popular, at your local grocery store. The other possible source of the smell is sewer gas backing up into the dishwasher. This happens because the waste water connection from the dishwasher is linked into the pipes under the sink after the P-trap. Take a look under your kitchen sink, locate the connection where the dishwasher wastewater pipe connects to the sink pipes leading to the main stack. Now follow the pipes from the sink drain down there will be a P- trap that prevents sewer gas from backing up into the house, your dishwasher connection should be between those two. If your P-trap is between the dishwasher conncetion and the sink drain then you are getting swere gas flowing into your dishwasher and this is what you are smelling. If this is the case have a licensed plumber come in and reconfigure the pipes so the P-trap is after the dishwasher connection and the smell will stop. It shouldn't take a plumber long and the parts are cheap. Hope this helps.
Oct 10, 2017 | Samsung Dishwashers
Washing machine sewer odor
The drain pipe that your drain hose goes into is more than likely the problem. The drain pipes should have a p trap which looks kind of like an S- shape the water stays in the trap preventing the smell from backing into your home . If there is none, install one.
Jun 09, 2013 | Washing Machines
Newer Maytag dishwasher smells really bad inside
This problem can normally be fixed very simply and you can do it yourself.
1. There is a flexible drain line that goes from dishwasher to the sink drain line or garbage disposer.
2 You will find this flexible drain underneath the kitchen sink.
3. Make sure that the flexible dishwasher drain line goes up above the sinks lower portion of the sink basin and then comes back down into the sinks drain line or grabage disposer. The dishwasher flexible drain line must go above the bottom of sink basin like an upside down u shape, it will act as a upside down p-trap that you see under the sink in the sink drainline.
4. Once you have the flexible dishwasher drain line in this configuration (upside down U shape or p-trap) it will prevent air from leaking out of the dishwasher as the smell you are smelling is coming from the drian line.
5. You should also look inside the bottom of dishwasherr to make sure the drain screen is not clogged up.
Sep 08, 2011 | Dishwashers
Bad smell in dishwasher, have cleaned and even used bleach. The smell just comes back. even smells on the dishes. the smell is like a stink bug.
Three things, dryer coil, food stuck inside.
Most washers have a one way valve on the drain and a water trap
created with the line, so no water or smell can go into the machine.
Check the valve, remove the hose,that should be under the sink,
wrap a cloth around it and blow,it should not be able to blow into it.
Then make sure the hose at some point go higher then where it
connects to the drain.
Fill a bucket and fill the washer until you see a little in the bottom of the machine, watch it for a few minutes to see if it drains, it
shouldn't, dump in a bottle of white vinegar and run the machine, make sure dry is off. Then run it again, do not add anything.
Feb 17, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
I have a Whirlpool Duet front loading washer with a smelly trap.
It is normal to have water in the drain lines and drain trap even when the unit is not in use. There's usually about a gallon of residual water in the lower portion of the wash tub, drain line and pump. If you are experiencing sour odors from the washer, the following link can give you some pointers on things to try to help keep the smell from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Read through the link provided and let me know if you still have problems. I personally own a front loader and have followed this regiment for 9 years now with no odor or mildew problems. I hope this helps you as well.
Jan 28, 2010 | Whirlpool Washing Machines
Maytag Quiet Series 300 smells broken door latch and lower rack
I have had the same problem and there is a simple fix.
The problem in my case was the floating water sensor was stuck and gummed up with grease.
On the bottom of the dishwasher, in the front right corner there is a round doughnut-looking thing. This is the water level sensor. It is open on the bottom, and grease collects there.
When this happens, the air pocket is too small, and the float won't float. then the dishwasher overflows. To clean it: just reach under with your finger, and scoop out the grease.
Sometimes, after doing this, the float then gets stuck in the "up" position. When this happens, the dishwasher completely drains, and the heater element for the dishwasher is exposed, and food cooks onto it, and that is where the smell is coming from.
Sep 05, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
LG washer smells
Have you tried doing a 90 degree wash. This will get rid of bacteria that causes smells.
Aug 19, 2009 | LG WM1812C Front Load Washer
Very bad smell coming from dishwasher
Possibly a water leak underneath or a dead mouse behind the unit.
Mar 17, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Nov 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint 24 in. HDA3700G Built-in Dishwasher Logo
1,329 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
