Question about Canon DC100 DVD Camcorder
Turn on canon dc100 everything come up fine pop the disc in already, still say no disc with a disc sign in red with a / keep flashing, even try with dvd r and rw , does not work....please help !!!
  • tjds007 Jul 14, 2008
    turn on canon dc100 everything come up fine pop the disc in already, still say no disc with a disc sign in red with a / keep flashing, even try with both dvd r and dvd +rw , does not work....please help !!!
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is it a DVD-R or a DVD+R disk?
  • 4 Answers
If the camera is still not working with DVD-R and DVD-RW discs you may have to have it repaired. Try resetting it first (the reset button is behind the battery) and that doesn't work you may have to have it repaired. I had the same problem and I took my camera to an electronics shop and they found that my CCD sensor is not working so it has to be replaced. The total cost for the repair is $140, ($50 for parts and $90 for labor)
Posted on Jul 15, 2008
  • Canon Master
  • 2,794 Answers
Here is the infomation on the specs of your camers
You camera will only work with DVD-R and DVD-RW disks.
Posted on Jul 14, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: no disc read on dc100
There are only 4 possible solutions,
1. Dirty or faulty discs, but as you've tried different discs this doesn't seem likely.
2. Condensation has developed in the camcorder, leave it in a dry indoor temperatured place for a couple of hours and try again.
3. Dirty lens won't let the laser read the disc. Look for lens cleaning camcorderkit in a store.
4. Manufacturing error
Hope this will help you.
Posted on Jul 16, 2008
I just bought new discs for my Canon DC100. The
It's possible that, for some reason, the disks aren't compatible. It can almost drive you crazy trying to figure out why. To find out for sure if this is the case, try some new Panasonic discs, with the same specifications as the old ones that worked, and see if they work. If they don't work, you're probably having a dvr issue with the laser lens or related parts within the camera. There are many issues with dvrs that develop over time, requiring replacement parts and service. In those cases, it's usually better to get a replacement camcorder. The new HDD camcorders are immune from a lot of problems inherent with dvr and tape recorders.
Apr 18, 2010 | Canon DC100 DVD Camcorder
How do i put my camera in the still frame mode?
follow this link to your manual
http://lib.store.yahoo.net/lib/starbattery/DC100.pdf
1 open cover and move slider down to C
2 press the stop start half way
once auto focus is adjusted O will turn green and 1 or seveal af frame will apear.
3 press start stop fully
the DISC access indicator will flash as image is being recorded.
Nov 15, 2009 | Canon DC100 DVD Camcorder
Canon DC 100
check your battery or change it..battery output should have 7.8v.
Oct 31, 2008 | Canon DC100 DVD Camcorder
Finalize the disc
depends what type of disc-rw's won't highlight sometimes because they don't always need to be finalized to play-insert the disc if r in another brand and see if you can finalize-go to bb or circuit and ask them if you can stick it in display and see if it comes up-if never proably was done already-also try different dvd players
Aug 24, 2008 | Canon DC100 DVD Camcorder
No disc read on dc100
Jul 14, 2008 | Canon DC100 DVD Camcorder
Pop a dvd r/rw in it reply no disc
I just got an estimate back from the electronics shop that is going to fix the camera. According to them the CCD optical sensor is not working so it has to be replaced. The total cost to fix the camera is appx $140 ($50 for parts and $90 for labor) If you try resetting the camera first (the reset button is behind the battery) and it doesn't work, this could possibly be your problem.
Initializing DVD-RW Discs
This camcorder only takes DVD-R and DVD-RW, it will not work with the +R discs. I've used Maxell and Fujifilm discs and they both worked fine. You have to make sure the camcorder is plugged in the wall when initializing or else it won't initialize.
May 22, 2008 | Canon DC100 DVD Camcorder
Canon DC 100
Is there a disc in it if not its supposed to say that.
Nov 22, 2007 | Canon DC100 DVD Camcorder
Finalzing my disc
you can only finalize a disc in the dc100 with the power adapter on. (page 59 instruction manual)
Aug 01, 2007 | Canon DC100 DVD Camcorder
No disc
some DVD's aren't compatable with the DC100 they must be the DVD minus and moisture can also cause this but Call Cannon Support 800-828-4040 they have a 1 year factory warranty & will repair without charge if it is a defect
Apr 04, 2007 | Canon DC100 DVD Camcorder
Canon DC100 DVD Camcorder Logo
196 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
