Question about Linksys Wireless-G WRT54G Router
Linksys router When I hook up the router per instructions I loose my internet connection. I am connected DSL embarq.
  • rom123 May 11, 2010
    I use to have the router work but, when I disconnted the router
    I can't get my router to connect to the internet
  • 2,794 Answers
Unplug your DSL modem. Wait 30 seconds and plug it back in.
Make sure the router is connected to a DSL modem. Lately I have seen DSL modems connected to offices that are really routers. If thats the case it may not be talking because the DSL is address the gateway with the same address as the router.
The best way to test this is to see what happens when you disconnect your linksys router and type in http://192.168.0.1
in internet explorer.
If the DSL modem screen appears, it's configured as a router.
Then you will have to take the linksys router and turn it into a switch with a wireless access point. I
Posted on Jul 14, 2008
Every time i hook up the wireless router to the dsl router it doesnt find the internet ( its is a embarq 660 series dsl router and i have a belkin N1 wireless router)
the problem you are facing is due to the double nat issue(the embarq modem provides the ip address in the range of belkin router, that is 192.168.2.1)...hardwire the pc to the lan port of router.
login to the router setup page(type 192.168.2.1 in IE)
in router setup page, click on lan settings and change your lan ip to 192.168.5.1....the problem ll get resolved...if still the status is not connected, switch off the router and modem and switch on it after a minute....it ll get fixed
Feb 12, 2010 | Belkin (F5D8231-4) Wireless Router...
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
Nov 09, 2009 | NetGear WGR614 Wireless Router
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
Linksys wireless router problems
Power down all the units. Power up the DSL first. After it is up, power up the router. After that is up, Power up the laptops one at a time. Let me know if this helps or not, there are other things to try after this...
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Hooking up wireless linksys
From ethernet of embarq plug it to the Internet port of Linksys. Your PC should be connected to port 1 of Linksys
Belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Jan 05, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
169 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
