I have a philips mini stereo system and it will just stop making a sound. the lcd panel still works but no sound comes out then it freezes and you have to wait about 30 seconds before it does anything
  • mg76 Jul 15, 2008
    thanks for your help!
  • 2,071 Answers
Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the philips receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Posted on Jul 14, 2008
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
Hooked up HDMI cable from receiver to tv, no sound coming out of speakers, am/fm works through speakers fine, is there something I need to do with my tv to make it work, and does it matter which HDMI port...
The HDMI ports on your television are not audio ouput ports, they are same as component INPUT, but with all in one cable. The only way you can connect your tv to your stereo is by adapting the headphone jack on the side panel of the tv. Get a mini 3.5 mm y-adaptor to two rca female connection, now you can hook to your stereo using white & red L-R connections analog.
No other way to connect this. Refer to page 29 of your instructions manual.
Jul 15, 2011 | Philips 47PFL7403D 47 in. LCD TV
How do I connect speakers through the headphone socket
The best way to do that would be to put a receiver in the mix, The older the receiver the better, then just stop by your local radio shack and pick up a mini to dual RCA adapter, connect the RCA ends to your inputs on your reliever and wallah, not only do you have sound but pure driver powered stereo that sounds great. Of course the receiver will connect the speakers to the system.
Jun 04, 2011 | Toshiba 42XV540U LCD TV
Philips 32pf732198 no sound on certain channels
Unplug,replug the tv an hour later.Go to ur tv menu reset the Audio setting.The setting will go back to the factory setting,should work solved ur problems.Not than ur Tuner signal board have problems,must change.
Apr 06, 2010 | Philips 30PF9975 30 in. LCD HDTV
No sound on channel 69 on my philips tv LCD
use youe remote and make sure sound setting are in Stereo mode Not SAP
Nov 02, 2009 | Philips 42PFL5332D 42 in. LCD Television
Getting sound through mogen lcd tv
Yes, you need a 3.5mm male mini stereo to male mini-stereo cable. Plug into small hole in monitor to lime green port of computer352d_2.jpg
Jul 06, 2009 | Computers & Internet
Setting up tv sound to come thru stereo speakers
Offhand, your Philips 32PFL7422/98 do not have regular Audio Output RCA jacks (white and red), sorry. However, right before the antenna connector is an S/PDIF output connector. This should allow transfer of digital audio signals from the Philips 32PFL7422/98 to a S/PDIF capable receiver or amplifier. If you would look at the rear of your stereo and determine if it has such an input, then it would be a matter of getting the right cable/connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Philips Televison & Video
Shelf stereo turns off by itself and stops working all together.
how loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Feb 04, 2008 | Philips FW930R Shelf System
AM/FM Stereo Hookup problems
Make sure your audio outputs are turned on.Also try a connection from the tv straight to the stereo to see if you have sound !! If so then the problem is somewhere in between!! Check the settings for audio on these devices as well !! Good Luck !!1 Swampratt200 AAAAAAAAAAAAAAEEEEEEEEEE!!!!
Nov 03, 2007 | iLO 3200 32 in. LCD Television
 Grubhead
Grubhead
