Question about Dell OptiPlex 170L PC Desktop
I am getting the following error Every time I start the optiplex 170L PC. Its probably a hard drive error huh. It seems that the PC automatically one day Shut down and got the following error and my PC isnt usually powered on most of the time. any fix for this??? I wonder how I can disable this SMART technology. Of course we can do it in Hp pcs.
notice:The primary IDE master hard drive SELF MONITORING SYSTEM has reported that a parameter has exeeded its normal operating range
dell recommends that you back up your data regularly.
A parameter out of range may or may not indicate a potential hard drive problem.
Strike F1 key to continue, F2 to run setup utility.
  • Anonymous Dec 20, 2008
  • 2,692 Answers
Sure sound like you hard drive is starting to have a problem. I would clean and defrag it after backing it up. start- my computer- right click on hard drive-properties-disk cleanup/  After that then 'tools defrag hard drive. then run scan disk
Posted on Jan 13, 2009
How do I fix a problem were a tower computer won't see the slave hard drive.
It sounds like both drives are trying to be the master on the cable. Have you tried setting both drives jumpers to the CABLE SELECT setting. This allows the BIOS to individually identify them and you specify in the BIOS which is the primary boot drive.
Mar 22, 2016 | Dell Computers & Internet
No boot device available dell optiplex 170l series
Go to the bios to verify that the computer is recognizing the hard drive and that the hard drive is is listed in the boot sequence. If this is all good your hard drive may have been formatted or erased or the boot record is corrupt and unreadable to the bios. I had a similar problem. reloaded windows and all was good.
Feb 12, 2013 | Dell OptiPlex 170L PC Desktop
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
How can I clean the hard disc & re-install windows on my Dell Optiplex 170L computer?
Put the windows cd in the cd drive. Restart your computer while pressin Del or F2 to go to the system BIOS and go to Advanced BIOS settings and go to boot order or boot sequence, select Cd/Dvd to be the 1st device on the list. Hit F10 to exit. Your computer will restart and boot from the cd. On the first screen, just press enter. Then F8 to accept license agreement. Then you will press esc. Select the partition that you want to clean up! Select the first option (quick NTFS), then press F to start formating! Wait and follow the instructions on the screen.
Dec 13, 2011 | Computers & Internet
I was to put in second hard drive what is the interface of the hard drive I need to get?
you could have either sata or eide interface these were /are pretty popular computers here are pictures of both they should help wish you the best of luck and please vote eide is the big one on the leftmmessner1_9.pngmmessner1_8.png
Nov 29, 2010 | Dell OptiPlex 170L PC Desktop
Installation of IDE and Sata Hard Drives at a time
set your computer's BIO settings to default through the F2 button then connect the IDE fast and make sure its the master with an Operating system on it then connect the SATA after the IDE has been detected.
Nov 09, 2009 | Dell Optiplex GX280 (99301) Motherboard
Can't access hard drive getting IDE master hard drive SMS mess
You are getting a SMART error indicating that the hard disk drive is/has failing/failed. Likely, the only way to get data off the drive is to send it to a data recovery center, then install a new hard drive. Data recovery is generally expensive, but if you are interested you can contact places like DRIVESAVERS 800.440.1904
May 27, 2009 | Dell OptiPlex 170L PC Desktop
Dell optiplex 170L hard drive recognition
Ms Driver gets flaky sometimes. Get New driver from Dell Downloads.
Contact Dell Support for more INFO
Oct 08, 2008 | Dell OptiPlex 170L PC Desktop
Hard drive
If you look at the hard drive inside your computer, there will be 2 cables plugged into it. If one of the cables is a flat cable about 2 inches wide, then its IDE interface type.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Sep 05, 2008 | Dell OptiPlex 170L PC Desktop
Dell OptiPlex 170L PC Desktop Logo
1,565 people viewed this question
Alun Cox
