Question about HP Office Equipment & Supplies
I have a hp c6280 all-in-one photosmart printer. i changed the hp vivera colored ink cartridges. the printer will not work and prints out that the error is pump motor stalled.....printer documentation error 0xc05doo82. what should i do to correct this?
  • Anonymous Mar 27, 2014
    the printer is not working
I had this same problem with my c6280.
I got fed up (HP only added frustration) and decided to trash it and buy something new.
So I figured I would take it apart and see if it was something obvious, worst thing that could happen was that the printer would not work - allready there.
Here is what I found.
Taking the covers off of this printer is not easy, but after removing all accessable screws I was able to get the covers off.
I found the pump motor on the left side of the printer (it is labled).
The pump motor has a large (approx 2 in) gear on it that is drivin by a belt with teeth.
The other end of the belt is drivin by a small (approx 3/8 in) gear.
There are two belt tensioners on each side of the belt.
PROBLEM; The belt was not riding on one of the tensioners.
This causes the belt to intermitenly engage the gears (stalled pump motor).
I put the belt back on the tensioner, put the covers back on (a real pain).
Printer now works fine.
I think that this may have been a problem out of the box because the lound clicking noise that came with the printer has also gone away.
Posted on May 06, 2009
  • 2 more comments
  • antonioc83 Dec 24, 2010
    I first received the error message of improper shut down then this pump motor stalled error message just appeared and after hours of looking at online forums i decided to take a look inside the printer and saw that the what i assume was the motor gliding on the straight metal bar was not gliding so smoothly so i decided to spray some WD-40/oil on the track and it seem to have done the trick, i couldnt believe it. What i did exactly was spray some right where the motor and the bar was, let it do the printer preparation then sprayed some more. Didnt have to take apart anything just lifted the access door. Hope this helps.
  • johnkoch39 Mar 14, 2011
    After I got the cover off (YES, it is a real pain - and be careful!) I found a small piece of paper - (must have been torn off the corner of a jammed paper that I thought I had cleared a week ago) stuck in the far right. It was not visible before I took the cover off. After removing it and replacing the cover I was able to print again.
  • Buick712002 Apr 09, 2011
    I also took it apon my self to take my printer apart. Thank god Im mechanically inclined. It was a small belt that was off the pully on the right hand side. It was making a bad grinding noise, So if anyone has this problem with a alighment problem then this is it get your torx bits out and your small flat head screw driver. I think its the way it was packaged from the HP factory.
  • dmryan1
    dmryan1 Jul 15, 2012
    Problem: Pump motor stalled. Fix:
    Open up the printer where the color printer ink cartridges are located. In the opening behind the ink cartridges, you will find metal bar for the pump motor. Put three drops of light oil on a small cloth, wipe it across the length of the straight metal bar, starting from right to left. Restart the printer, letting the pump/motor assembly pass along the bar. You should be good to go. The total cost = 5 minutes of your time, 2 cents of oil, and a quater sheet of paper towel.
I have the HP photosmart C6280 printer.. 2007 edition and it has all different color ink cartridges, the yellow ink is almost out so it will not let me print anything. I am just trying to print off a word...
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
http://www.fixya.com/support/t6288403-hp_8050_printer_message_says_color
Sep 30, 2010 | HP Photosmart C6280 Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Use of 852 and 855 cartridge in hp 6210 officejet printer
This quite often happens with CLONE cartridges and happens very infrequent with original cartridges.
The cause is the ink level chip used in clones is quite often a very cheap chinese copy and very prone to failure or misalignment
Either way take them back and get them changed is my advice
Aug 17, 2009 | HP Office Equipment & Supplies
My C6280 printer says the black is empty but it is
Dear Sir,
Printer doesn't identify the ink accurately all these are controlled by software only.So it is showing your black cartridge is empty but trace amount of ink actually remained,by this you are getting black and white prints correctly.After the consumption of that trace amount of ink it may print black text as a greenish-brown because printing taking place only by means of color cartridges.So if you observed blurred text or greenish-brown text, now you can replace your ink cartridges.
i think it helps
good luck
Aug 11, 2009 | HP Office Equipment & Supplies
Ink System Failure on a HP Photosmart C6280 All-in One
This is likely a cartridge problem except if the carriage is not moving at all. If you still have some of the used cartridges you can used them to trouble shoot by elimination ok. Or contact a nearby technician who has the cartriges to use them for trouble shooting. I strongly believe the one of the print carts is the culprit. Good luck
Jun 02, 2009 | HP Photosmart C6280 Printer
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
Will not copy in color. copy black perfect.
I sented it in to HP for them to fix the problem.
Feb 03, 2009 | HP Photosmart C6280 Printer
HP Photosmart 8250 with Vivera ink
how long have you had your printer an how is the color working on printing?it may be stopped up trying cleaning it.try some alcohol on the end of the qtip dont put much on it .clean where the catridge goes into it where the cartridge makes a connection.then run a test page.let me know.
Jul 10, 2008 | HP Photosmart 8250 InkJet Printer
1,050 people viewed this question
Seeker5211
Seeker5211
