Televison & Video Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AUDIO BUT NO PICTURE (JUST BLACK SCREEN) COULD BACKLIGHT BE DISCONNECTED
Anonymous
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Expert 358 Answers
  • Posted on Jan 18, 2011
Anonymous
Expert
Level 2:
Legend:
Answers
358
Questions
0
Helped
141371
Points
438
Thorburns10,
You might check the connections on the back of your TV to make sure they are tight. What type of receiver do you have feeding your picture? Check that also. I hope this helps.
Ray Calo
DISH Network
2answers
Sony Bravia flat screen TV when turned on has black screen. Green light on the bottom is lite up, electric plug is plugged into house socket, no picture only black screen.
If audio is OK, the fault is with its backlight section. If audio too is absent, the fault is with its digital main board. If you wish to get more details visit the site linked here. Pull up older posts.
http://homenol.blogspot.com/
The TV will power on - but there is no picture on the screen. We have unplugged and even changed outlets, disconnected HDMI cables and still nothing but a black screen.
If you have sound, look close at the picture use a flashlight if you need to. If you can see the image, then the backlight or inverter is bad.
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV display is black; audio works fine. If I turn TV off and then back on the picture does display for a few seconds but then...
The backlight inverter which is also part of the power supply needs to be replaced. If you feel comfortable you can replace the blown capacitors on it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Turn my plasma has audio but the picture is not visible black
A LCD may have backlights but Plasma sets do not for the most part.
If backlight does not come on--no voltage reaching it, not being turned on by the set, or backlight is bad.
1helpful
2answers
No video,screen is dark,there is audio
Hi doubles,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
6helpful
2answers
Screen went black...audio still working..Shuts off after 5 seconds..LG 32lcd7d 42" flat screen
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board.U will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
2helpful
JVC LT-37X688 37 in. LCD TV. When powered on there is a brief flash of light on the screen and then the screen is black and stays black. Audio is fine and I can still use all of the remote controlled...
No lamp on LCD tv.The LCD backlight inverter board it dead,that board needed replaced to get picture back.Tries Shopjimmy.com,Ebay.com to buy the LCD backlight inverter board.It usally a long board.The refurbish LCD backlight inverter board about $100-$120.
1helpful
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Top Acoustic Research Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Acoustic Research Televison and Video Expert? Answer questions, earn points and help others
