Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore 596-77532600 Help all the lights on panel are blinking and the Ice door keeps opening and closing I can't find out whats wrong can you help me fix it?
  • 87 Answers
Well well well sounds like you have a ghost! just kidding! try to level the unit. It does have a float in it. This float will dictate if its off level. thuss shutting the unit off and on because it is just between being level and not level if you know what I mean. just to try and shut the unit down for about 5 min. then start it back up . by unplugging it.then leveling it . now remember to level the floor first to see if the floor is level. I know you might think your floor is level but the fact is 19% of every home has an un level floor even in new homes . (it happens) it just is not noticable to the eye. thuss 2% = a off amount big enough to off scale your unit. not to worry. your unit has screw levels on the 4 legs they look like wheel's it ok . a dollie will be fine or a helper. just to pick it up ever so slitly in the front and reposition it . now most people just use a deck of cards like 2% would = like 7 cards place 7 on both sides of the front to pitch it back or 7 in the back to pitch it forward. so on. but remember to check the floor. then place a level on the fredige it self.in the end i dont care how unlevel your floor is has long has the level bubble is in the center on the freedge in the end. i type this rely fast so forgive me I must move on.
Posted on Jul 14, 2008
  • 2,427 Answers
Yeah the switch to open the ice door is stuck or shorting,, or the locking mechnisim for the door is stuck.
I'd recommend you call a service technician immidately or A refrigator Ac, specialest, do not attempt repairs your self. Unplug and leave it until the technician arrives.
  • 796 Answers
First thing to check is to make sure there are no food items extending beyond shelves in ref compartment as well as door shelves. Door gaskets rolling under will cause it as well and may need to be replaced. sxs may have a broken door closure on bottom hinge or a bent door stop on all models can interfere with door closing properly. Check at bottom for interior panel rubbing interior cabinent liner and usually can be corrected with door hinge adjustment or additional bearings added to lower hinge to raise door a bit.
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
No water from dispenser
chances are dispenser board is bad check power going in the board should be 120 volts and power out if no power out replace board
Dec 17, 2007 | Kenmore 25.1 cu. ft. Side-By-Side...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Exterior lights blink, ice door opens and closes on own?
im honing my psychic powers here, it a french door bottom freezer right?? Its built by samsung and the High Voltage board has failed. Had the same problem with one here
Sep 28, 2007 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
119 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
