Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid Professional 5 Plus - Runs at Full Speed
We have a KitchenAid Professional 5 Plus stand mixer that is approximately 3 years old. Tonight when my wife was using it, it seemed to be working normally. When I went to use it after her it started acting up.
What happens is when you turn it to the 1st speed (out of 10), it winds up and starts running as if I had turned it to 10. I played with it a little, unplugging it, turning it to 10 and slowly stepping down to 1, turning it to 1 and slowly stepping up to 10, etc. No matter what I try, this thing will not run at any other speed than 10. Any ideas what I can do about this?
I'm leaving it unplugged for the night to see if letting it sit overnight helps. I will probably call KitchenAid tomorrow, but don't anticipate a lot of help since it is out of the 1-year warranty.
  • 2 more comments
  • barbdonm Jul 21, 2008
    My Kitchen Aid mixer also runs at full speed only.What can I do?
  • Anonymous Jul 23, 2008
    my kitchen aid (lift bowl) seems to run fine most of the time but when used for a long time making icings last weekend it started to jump to high speed...for a while I could just turn on and off in spurts but then just stopped working...last night it seemed to work fine again...no small appliance services here...what am I supposed to do...its only about 2 years old
  • Anonymous Mar 30, 2009
    My KitchenAid mixer started jumping to the highest speed several months ago. It now works ONLY on high speed. Since I really can't afford a new one, and I suspect repairs will be beyond what I can afford, I've really had to make it work. This isn't easy as flour and liquids splatter all over my kitchen making clean up a nightmare. I purchased a splash guard which does little to no good. This seems to be a somewhat common problem, and I can only hope KitchenAid will address this issue soon.
  • Anonymous Apr 19, 2009
    On the first setting my Kitchenaide runs very fast.
  • 135 Answers
Hi. All of you have the same problem. The electronic speed control board needs to be replaced. This board can be installed without much trouble. The board is modular, remove the old board and install the new one. The wiring is connected by a modular plug.
Goto www.kitchenaid.com enter your model # and search for the parts manual. These drawings will assist you with the task at hand.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Mar 24, 2009
This happend to my KA as well. The problem was caused my the constant moving of the speed control which moves the control board forward and backward caused a wire on one of the connectors to break loose. When the wire was soldered back on all worked just fine. Remove the rear panel and look at the wires attached to the plugs for breaks. Ohn unplug thge mixer first.
Posted on Mar 07, 2011
KitchenAid mixer runs at full speed only
It is most likely the phase board which is the little PCB under the back cover at the top, it has 4 wires coming out of it that plug into the black speed control board.
Mar 05, 2014 | KitchenAid K45SS Classic Stand Mixer
Mixer has lost all speeds, only works when moving the lever back and forth. The mixer is about 9 years old.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 14, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid stand mixer KSM90EM turns off when going to the left on speeds 4 - 6. Makes a bit of noise at stir speed, but runs in time. Also noticed white dust powder in small amounts on the speed...
Get a Copy of the Repair Part List from Kitchenaid.com.
You need to adjust the mixer speeds:
All three (2 top left and right, and 1 bottom) must be adjusted. Make sure that the Control
Plate is not damaged in any way, contacts are not charred or burnt,etc...
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 30, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
My daughter's Kitchenaid Artisan 325 watt mixer had a malfunction last night. The unit itself is less than 3 years old. It had been running on high for approximately 5 minutes when sparks began to fly...
Sorry cant solve this but mine did the same. Mine is almost 4 years old now. Have you found out what the problem was with yours? Have you sent it back? Nicky.
Aug 02, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I have a Kitchenaid Professional 5 Plus Mixer beaters won't turn
It sounds like it has been overloaded and the worm gear has been stripped. You will need to take the head apart to confirm this.
Jun 24, 2009 | KitchenAid K45SS Classic Stand Mixer
575 watt 6qt stand mixer. start out on low speed
Hi. If your mixer is still under warranty, call Kitchenaid, they are usually very good at replacing mixers under warranty.
If you're out of warranty, you'll need to order a new speed control board. Use the following link to download the parts catalog for your mixer.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212278.pdf
You can remove and replace this board yourself. Use the drawings to assist you with the project.
Mar 16, 2009 | KitchenAid KP26M1X Stand Mixer
Kitchenaid ksm50pob no stir speed all other speeds seem ok
I don't know if it will work for you but move the speed lever from front to back a few times as fast as you can. This will polish the contacts. This is like the old fashioned TV tuners. People used to turn them slowly and then complain when they needed serviced every 6 months. Spinning the tuner knob kept the tuners working flawlessly for years.
Jan 08, 2009 | KitchenAid KSM50PR Professional Series...
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
550 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
