Question about Acer Computers & Internet
I am havimg trouble with setting up a dial up connection says there is no modem
  • 2,427 Answers
Check that the drivers for your modem is installed,
start / right click computer and choose properties then device manager,,
yellow highlighted componets means that there is an error
If its not install install them, If you need to and dont have the drivers, you can use a program like driver magician to download them for you or give you the hard ware make and modle in which case you can google them
if it is installed then you may need to setup the modem, go into the control panel and select Modems or Dialing devices then add,'
select the modem you want installed and thats it.
Posted on Jul 14, 2008
DSL NOT STANDING.
If you are having trouble with the modem, call your isp to get this trouble sorted out.
Apr 20, 2014 | Computers & Internet
AOL Dial up on Windows 7
Click on the Network Connection icon in the bottom-right hand corner of the start menu (next to the system clock). This will bring up the Network Connection window. Depending on how your computer is set up, it may look like either of the icons below:
Click Open Network and Sharing Center at the bottom of the Network Connection window.
Click Set up a new connection or network in the Network and Sharing Center.8896771.jpeg
Select Connect using a dial-up modem and click Next.
On the Type the information from your Internet service provider (ISP) screen, enter the details as follows:
a) Dial-up phone number: 0198308333
b) User name: Your full Westnet username. This will generally be in the format of yourusername@westnet.com.au, or sometimes yourusername@wn.com.au.
c) Password: Enter your Westnet password. This is case-sensitive, so ensure your caps lock key is switched off and you are entering your password in the correct case.
d) Connection name: It is recommended you change this to Westnet Dial-up Connection.
e) Allow other people to use this connection: If you have other Windows user accounts on this computer, and you intend for them to be able to use this dial up connection, check the box. Otherwise, leave it unchecked.
f) Ensure you have connected your modem to the phone socket, and click Connect. This will automatically attempt to test the new connection by dialing up to the internet.
To reconnect to this dial-up connection in the future, click the Network Connection icon in the bottom-right hand corner of the start menu, click Westnet Dial-up Connection, and then click the connection button.
Jun 24, 2010 | E-Machines eMachines Desktop PC
Connect to a wireless and change from dial up mode
it will work fine.just install the drivers and it will pick up the signals from wireless router or modem..dial up and dsl are two different connections.
Mar 14, 2010 | Dell OptiPlex GX270 PC Desktop
Trying to connect to internet but screen says internal modem has no driver - it sees no modem
If you're compuer is connected to a router or DSL/Cable modem through Ethernet connection, you don't need to have to use internal modem. Internal modem are just for dial up connection.
If everytime you launch IE browser and it gives you that prompt, your browser may have set up to connect everytime to a dial up connection. Try to check these settings on your IE:
1. Go to Start> Settings> Control Panel> Internet Options
2. On Internet Options, go to Connections tab.
3. Delete everything under Dial Up and Virtual Private Network Settings, Or just set it to 'Never Dial A Connection'.
4. Click on LAN Settings button.
5. On the next window, uncheck everything (particularly the proxy setting).
6. Click OK all the way out.
Oct 23, 2009 | HP Pavilion a1610n PC Desktop
My new pc Dell Inspiron desktop has no modem built in for dial-up internet connection. Im currently subscribing to a dial-up service provider on another pc, how do I connect to the same dial-up service...
You have to configure Internet Connections Sharing on the PC which has a dial-up service.
1. Click Start - Settings - Control Panel - Network Connections, right click on dial-up.
2. Clik on Properties, click on Advanced tab.
3. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box
After that you must connect the other pc to this one via network cable.
If you don'y have network adapters you have to buy them.
Sep 30, 2009 | Dell Inspiron 530s Desktop Computer...
Failed to connect to dial up connection
Double click on modem in control panel and check properties. Make sue drivers are installed and it is set to wait for dial tone. Does the modem attempt to dial out at all. Is there any error messages? Is the phone cord connected to the pc and the wall and is it in good condition. There are many possible reasons and everything needs to be checked. Lets start simple first. Do those things then post results.
Dec 21, 2008 | Gateway Computers & Internet
Wizard wont create a dialup connection using vista i have updated the modem drivers and the modem is in my device manager
Hi
Follow these instructions to create a dial-up connection on your computer. Then you can get on the Internet to receive/send email and browse the web.
From the Start menu, click on Connect To
Click on Set up a connection or network
Click Set up a dial-up connection
Click Next. Enter the required information for the connection:
Dial-up phone number: 513-520-1135
User Name: (the NCF accountID that was assigned to you)
Password: (the password chosen by you when you registered)
Remember this password(check this box)
Connection Name:NCF Internet - Libertel
Allow other people to see this connection: Check this if you want this connection for all users on your computer (recommended)
Note: if you have Call Waiting, temporarily disable it for the duration of your NCF connection byusing *70,,613-520-1135 as the phone number.
*The NCF dialup phone number is in area code 613 in Ottawa. Please note that long distance charges may apply to modems outside of your local calling area.
Click Connect to create and save this connection.
You have successfully created a Dial-up Connection in Windows Vista.
To connect to the NCF using the connection you have now created, follow these steps:
  1. Click on Start, and then Connect To.
  2. Left click on the NCF Internet - Libertel dialup-up connection and select Connect at the bottom.
  3. The Dial-up windows will come up. Simply click on Dial and your computer will connect to the NCF
Jyothish
Jul 18, 2008 | Computers & Internet
Connecting to Internet using a dial-up modem
can you connect that modem first, to a phone line, and run a telnet or dial connection from control panel or accessory ?
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Brian Sullivan
Brian Sullivan
