Question about Samsung SyncMaster 753S 17" CRT Monitor
Samsung Syncmaster 753 s vga-connectig cable
Dear sir can you please give me the pin-out configuration of the 15 pin vga-plug with it,s colour-coding or wire diagram of the connectig cables of the Samsung Syncmaster 753 s  117 inch monitor
  • Anonymous Mar 25, 2014
    Connect Samsung Syncmaster 910mp to pc with VGA splitter, cann't able to see pc on monitor
My smasung monitor sync master 753 vga connector broken, what is color scheme for new connector
Colour scheme to re wire is as follows...
Pin Name Function 1
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Hope this helps!!
Jul 19, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Cable color codes for samsung syncmaster 753s
I want to fix new vga connnector on my smsung syncmaster 753s monitor and i am confused with colour coding please help me
Mar 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Vga pinout schema for samsung 753dfx
Apparently what you need are the wiring for the VGA cable itself. They would differ from manufacturer to manufacturer since it is not a Samsung item. Would the schematic and/or Service Manual of the Samsung chassis AN17K (753DFX, 76DF, 753V, 753S, 76V or 76E) help? if so, pls try here, here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 16, 2008 | Samsung SyncMaster 750S Monitor
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
The Red Colour Loss On My Samsung SyncMaster 753 DFX
My Dear Friends,
I Understood the problem.
I will explain it a little briefly.
There is an Integrated Chip (IC) inside the monitor which gave RED, GREEN and BLUE ( Primary Colours) to the CATHODE RAY TUBE (CRT) otherwise called monitor screen.
Due to long run, the IC might be cold soldered and one or two of the colours will not be supplied by the IC to CRT. so the CRT (monitor) will fail to display and mix the primary colours to get othe orginal colour.
The SOLUTION is to replace the IC with a new IC. As this requires a little bit expertise, please get help from the monitor service technician and ask him to replace IC with a new one. This can be done in home, so that you don't have to take the monitor to shop or service center.
All the things you have to tell the technician is to come with a stand-by ICs (NEW) for the MONITOR MODEL, in this case "SYNCMASTER 753S".
It cost around Indian Rupees 300/- for the cost of IC and another 200 Rupees for the service charge of technician.
I hope you solve this issue, if not write to me at spiceprince@yahoo.com with all details.
Spice Prince
Apr 10, 2008 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Replacing vga cable
A VGA cable is a D-Sub 15 pin cable.
Connector information:
http://en.wikipedia.org/wiki/VGA_connector
Pinning information about midway down the page:
http://myhometheater.homestead.com/vgacable.html
Is that what you were looking for?
Mar 27, 2008 | SAMTRON 55V 15" CRT Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
1,327 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
