Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I Have the same problem! Please Help!
The washer will fill up with water but wont aggitate, spin or empty. I can hear a quiet humming like the motor is trying to run.
    Problem Solver:
  • 6 Answers
Try tipping the washer over forward and look to see if the belt is still in place. If so, make sure it is tight. Have you tried setting the control knob on the control panel ahead a click at a time manually?
Posted on Jul 29, 2008
Wwa7304vkl motor hums but does not start
motor is going out on your machine.
Jan 05, 2013 | Dryers
Washer will fill up lid switch clicks hear timer running and advances but will not aggitate spin or empty water
sound as though you have a wiring problem around the motor harness..Or you may have to cheak for current across the switch when you click it on and off.Hope i helped:)
Jan 24, 2010 | Maytag LAT3600A Top Load Washer
GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Mar 05, 2009 | GE WJSR1070A Top Load Washer
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
Washer wont aggitate or spin
I think this is the direct drive model, no belt. There is a coupling between the motor and transmission that needs to be replaced. This is a common problem with that type washer.
Dec 21, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSQ9549lW0
sounds like something is stuck in the water pump. look under the machine and you will see the water pump front and center of machine.
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal De
