Question about Pentax Optio M20 Digital Camera
Flash problems flash will not go off no matter what mode i am in there is a red flash sign that goes off but no flash and because of that the pictures are dark and blurry
  • 797 Answers
What you are saying is that the flash will not flash. (go off), if I understand correctly.
First, make sure that the flash is on.
The flash can be turned off in most modes.
Another thing to try is to RESET ALL in the menu.
Then go back and set all the options like you want.
If the flash will not work in any mode, and you cannot get it to work, you may want to sell it on some site as Ebay, and offer it for repair, as is, or parts.
Posted on Jul 19, 2008
Why does my kinivo bth220 headphones have a flashing red light on them no matter how long i charge them and they will not turn on
The batteries won't charge. You might want to google around for replacement batteries.
First I'd try a factory reset. PRess the +, - and multifunction button for 6 seconds until the blue light flashes and it shuts off. When you turn them on next, it's in pairing mode and try again.
Aug 10, 2014 | Kinivo Bth220 Bluetooth Stereo Headphone -...
My daughter can't take pictures outside as the flash goes off and it just gives a white picture as it's too bright, what can I do?
1. You could try pressing the reset button. 2. You could press the "delete" button to change the flash mode when you first turn the camera on. 3.=Please check your flash setting to make sure that you don’t have the camera on forced flash mode (indicated by the lightning bolt with the plus sign in the upper right corner).
Using this setting in strong lighting conditions would result in a picture with too much
light.
4. If all else fails, you can call 1-800-521-2010
Aug 17, 2010 | Vtech Kidizoom Digital Camera
Samsung S730 camera wont take photos with flash
�� When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
�� When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
�� Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of
Movie clip mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Jul 23, 2010 | Samsung Digimax S730 Digital Camera
No flash
first turn ur lens wheel on the pyramid sign on the front then u can use right side of the push button that have zigzag sign to change ur flash mode for ur pictures
Jul 07, 2009 | Vivitar ViviCam 3750 Digital Camera
Nikon d40 all pictures are coming out red
yes it is BAD CCD PROBLEM widespread among all CCD cameras no matter which make which model
CCD FAILURE!
Call NIKON for Free Repairs it is a known manufacfault in thousands of cameras , dont worry just call them see this forinfo on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 29, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
What white balance mode are you using? Try changing it to Auto. Did you ever try to clean the sensor?
Jan 24, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
How do you activate red eye reduction in the 5900?
To take photos with red eye reduction requires your flash to firerapidly before snapping the pic. Make sure camera is in record mode pres the 4 way switch with the lightning sign on it. The flash modes will pop up. select red eye flash.
To fix red-eye after a photo is taken. Bring up the photo in playback mode and press menu button. Red eye reduction should be available as one of the menu items. Otherwise, display the pic, press OK button in center and if you like the fixed picture then select yes to store it.
Jan 12, 2009 | Nikon Coolpix 5900 Digital Camera
Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
Dec 12, 2008 | Nikon Coolpix S210 Digital Camera
Red hand symbol is flashing on the view screen
This is the sign warning you that the shutter speed is slow so camera shake is a problem. It means use a tripod or support the camera because holding by hand will cause blurred pictures that you see. When you see this sign you can either try to get more light on the subject or support the camera. This sign will also come on the low light conditions. Look at the shutter speed & you will see that this symbol will appear when it falls to about 1/60th of a second. Using a tripod is the best idea especially for a panoramic shot as when it is on the tripod you can turn the camera through 180 degrees taking overlapping shots then "stitch" them together in Photoshop or whichever software you use to create a single large panorama. If you don't have a tripod then put the camera on a wall or lean against something to give you more support. Good Luck!
Aug 10, 2007 | Nikon Coolpix 4600 Digital Camera
Pentax Optio M20 Digital Camera Logo
71 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
