Question about Canon imageRUNNER 1630 Copier
Clear Error Message
Hello!
On my Canon Imagerunner 1630, I was gettng the "Waste Toner Full" and "Prepare New Drum" messages. I replaced the drum, emptied the waste toner, installed a new toner cartridge, and everything works great but I still get the error messsages. Is there any way to clear them?
Thanks!
Bruce
  • Canon Expert
  • 287 Answers
Hello Bruce,
I want to help but I am a bit confused. First of all just to provide you with additional info, there are basically three criteria that cause a need to replace the drum. One ,as in your case,is when the waste toner level reaches a level that the waste toner sensor gets covered with toner and it gives you the prompt you received. What happens is that despite the fact that in an ideal world ALL of the the image that is formed on the drum to be transferred to the paper actually does transfer completely and therefore no waste. Real world is that a small portion of the image remains on the drum and is cleaned off and deposited "into" the cavity of the drum where the waste toner receptacle resides and the waste toner sensor does as well. Once the waste toner sensor sees an excessive level it generates the prompt you received and the cpu begins to count pages (and I'll be d$%&ED if I can find the exact number) and if the drum is not replaced the device will give an error code and shut down. We will return to this topic in a moment as it is truly the source of our dillema. The second reason to replace the drum is that copy quality has turned to ****. The 1023 drum is good for........laugh with me as to how they determined this number, 26,900 copies. Not 26k. not 27k. Collective ROFL. This second criteria manifests itself in just crappy looking copies, and the end user calls for copy quality problems. The third reason is the abstract. For example a foreign object damages the drum. This includes the human hand.LOL.
So, after all that hot air I just expelled I am at a loss as to why you are still getting an error message. The new drum should have satisfied all the requirements as the waste toner sensor is happy now, and there is no counter that needs to be reset. I am sorry that I could not be of more help. I know you will cuss me for saying this, but, power off and power on and see if that helps. And we cannot eliminate the fact that the waste toner sensor that resides in the drum unit is bad. Entirely possible.AND...remember that the cpu is counting only sheets of paper not toner usage. So if the copier thinks the waste toner is full, and it does not "see" that everything is ok now, it will give you an E-19 error code after so many sheets of paper pass by. I looked in the service manual and could not find a finite number of copies after the waste toner sensor gets pissed. Then the machine goes wheels up. If I can help further(like I helped alot this time) let me know. ...........SPINAL.......
Posted on Jul 19, 2008
I have message error for canon copier IR2016 "System Error E019" Please help me on how to fix
E019 usually means the waste toner is full. The waste toner is, I believe, in the drum, so you'll need a new drum. The drum appears to be under the front cover. You might want to call your service rep. if you are not comfortable doing this yourself.
Mar 20, 2011 | Canon imageRUNNER 2016 All-In-One Laser...
Message" Waste Toner Full....empty. Cannot locate waste toner, cannot locate manual. Will not copy. Please Respons ASAP. Thank you
waste toner is located inside drum unit.
Slide cover to the left, then open toner cover and remove toner, then open upper cover from rightsideway.By metal handle slide out the drum/toner unit out in right side.On top of the drum unit is cork. Open it and vacume out all the waste toner.
Put it back in and close all covers.
Hope that helps!
Aug 19, 2010 | Canon imageRUNNER 1630 Copier
Waste toner full prepare new drum on canon iR1570F
The waste toner is part of the drum unit. You need to replaced the drum unit with a new one.
May 24, 2010 | Canon ImageRUNNER 1670F Copier
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
I have a canon imagerunner 1630 had a paper jam and had to pull drum to get it out, now can not get it back in correctly, display reads check toner/drum crg
Before reinstalling the drum make sure the Developer unit is correctly attached to the drum unit. The two clips ( Blue slides on top ) keep the two items together. Canon had two screws that were to added make sure the two stay together when removing the drum. Anyway make sure the drum is squarely installed with you insuring the rear is pushed all the way down. The sensor is located below drum near the entrance to the fuser. Good Luck
Apr 06, 2009 | Canon imageRUNNER 1630 Copier
Copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
Mar 24, 2009 | Canon ImageRUNNER 1670F Copier
Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Jan 31, 2009 | Canon imageRUNNER C3200 Copier
Imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Jan 23, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Error message "Waste Toner Full Replace The Drum" which was replaced approximately one month ago.
Open the left cover,remove the drum.you will see on the drum unit there is plastic plugs that you can remove,remove them and remove the waste toner in the dustbin.put the plugs back and insert the drum in it's place.
Dec 04, 2008 | Canon imageRUNNER 1023iF Black and White...
Canon imagerunner 2010f wont print
You may need to go into service mode and reset the drum status. Service mode is dangerous and recommended for Canon techs only.
Aug 25, 2008 | Canon imageRUNNER 2010F All-In-One Printer
Canon imageRUNNER 1630 Copier Logo
463 people viewed this question
old marine
old marine
