Question about HP Pavilion dv4000 Notebook
Computer is stuck on welcome screen
I have tried restarting in safe mode, last known good configuration. computer won't go past welcome screen. what is the problem and how can it be fixed. this is on my sister's hp ze4900. i would really appreciate any advice
  • cowboyron Jul 14, 2008
    windows xp home edition
  • Dave May 11, 2010
    please post the OS you ar erunning XP or Vista?
    Sergeant:
  • 287 Answers
The file system (rather than the physical data) may be damaged on the HD. Try this:
1) Boot the computer using a Windows XP setup disk. (It doesn't matter if it's Home or Pro or what Service Pack. A Win 2000 setup disk should also work.)
2) At the first screen where you can respond, hit R to enter the Recovery Console. ***make sure it is RECOVERY not REPAIR***
3) At the command prompt you will get, type the command CHKDSK /P
When CHKDSK is finished running (it may take a LONG while), type EXIT and reboot from the HD. Windows just may start OK. **** DONOT reboot or power off untill it completes. Make sure it has mains power connected so batteries cannot go flat***
Posted on Jul 14, 2008
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Dell inspiron stuck welcome screen start
Hi sugi!
When you have experienced this the first time, what you need to do is restart your computer to the Windows Advanced Boot Options* then choose Last Known Good Configuration by pressing your up/down arrow key to highlight it then press Enter. If this option did not work for you, restart your computer again to Windows Advanced Boot Options*, but this time choose Safe Mode. Once in safe mode, perform system restore by following the steps provided by Microsoft thru this link.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Nov 04, 2013 | Computers & Internet
Restarting a nextbook
Please turn off the computer, start hitting F8 at the start-up and then choose last known good configuration. If this does not work, choose Safe mode options.
If still does not work, please try to restore the computer to factory settings.
Jun 02, 2013 | Computers & Internet
I have a toshiba protege 7100 series and it won't boot past the windows screen
Try hitting F8 during startup and choose last known good configuration.
Or you could try starting in safe mode and doing a system restore.
Have you made any changes to the system prior to this problem, as sometimes installing programs/drivers can cause similar issues. If so you will need to remove or configure the program causing the conflict. You can do this in safe mode.
Mar 13, 2012 | Toshiba Portege 7100 Notebook
My Acer Aspire one won't go past windows xp loading page but i can get on through safe mode, how do i get passed windows without it restarting?
go into safe mode then restart
when it turn back on press f8 buttonrepeatedly until the option screen appears select last known configuration option you should get in
May 30, 2011 | Apevia Aspire One A150-1777 Netbook
MY LAPTOP WENT OFF DURING UPDATES NOW IT WONT FINISH LOADING, it comes up update 3 of 3 then restarts and says same again keeps doing it not letting me in to lap top anymore seems stuck on updates
Hold F8 while booting to go into safe mode, or last known good configuration. Then, preform the update from there, and that should fix your problem.
Feb 28, 2011 | Acer Computers & Internet
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
My HP Mini 1000 XP will not restart, it gets stuck on the Windows XP welcome screen
Press F8 during boot this will take you to boot options select "Last Known Good Configuration" or select Safe Mode to perform a system repair.
To repair your system follow the steps below
1. Click Start and open Run on the Start menu.
2. Type (or copy and paste) C:\WINDOWS\system32\restore\rstrui.exe in the Run box.
3. This will open System Restore now select the first option (restore my computer to an earlier time) and click next.
4. Select a date when your network last worked and complete restoration.
Do not worry about selecting the wrong date you can always undo any restore within system restore you will select undo last restore.
Jan 12, 2010 | HP Mini 1000 Netbook
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Please select an option: Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
Computer crashed
by unplugging the adapter has not solved your problem because the driver is the cause of the crash. Try booting in safe mode again, but this time select last known good configuration, or boot in VGA mode(when in VGA mode uninstall the driver in add/remove programmes), if you get into last known good configuration your pc is working as normal. If none of the above work you may have to use your XP cd to do a system repair, if so post back
Sep 30, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
HP Pavilion dv4000 Notebook Logo
218 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
