Question about Shop Vac Vacuums
I need an on/off switch for a QSP series QPL30 vac?
I have a LL600 that has a defective switch. Where can I get one?
pastor@northsidebiblechurch.org
Posted on Jul 17, 2008
Is the shopvac qsp 10 for water
yes it is wet and dry cac go to link below for deiails
http://www.shopvac.com/pdf/Shop-Vac-QSP.pdf
Nov 08, 2012 | Vacuums
Lost manual for shopVac 5.0 QSP deluxe
go to www.retrevo.com or www. fitness.manualsonline.com
God bless you
Jun 18, 2012 | Vacuums
How can i replace or unclogg the hose ?model qsp 8
Remove the hose and lay it straight. Then using a broom or mop handle, push it into the hose and collapse the hose on the handle as far as you can. (Think crinkling your socks to pull them over your feet). You'll be doing much the same as you pull the hose up onto the handle. If you have no resistance from one end, then do the same things from the other end. Then replace the hose onto the vac and turn on the power. Your pushing with the broom/mop handle should dislodge whatever is caught and the suction from the vac should pull it through the rest of the way. I hope this helps. If so, please rate my solution. Good luck!
Dec 22, 2010 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Can't find manual
ask your local vac shop,they should be abel to get you one. they can help with any questions.
Oct 23, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Vacuums Logo
274 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
