Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Wd-52725 mitsubishi please help
We had t.v. on and suddenly there was a lod noise coming from inside sound like maybe fan? tried reset and letting cool still does everytime you turn it on and a minute or so after you turn off if you reset stopps immed. light is ready to be replaced but not out yet cleaned filter. I love t.v. please help. thanks!
Yes you were correct. color wheel bad, and had to replace whole color wheel engine 600$ part and 300 in labor. any one want to buy a 3.5 year old mitsubishi dlp with a new color engine and new light bulb? ;) we bought a new tv.
Posted on Aug 13, 2008
  • 927 Answers
Good day, anniedooday;
Your TV's color wheel is bad. Call an authorized service dealer to repair this. It's not an easy job.
Good Luck, big IRISH.
My WD-52725 mitsubishi 52 in tv is not working i turn it on and the fan starts but then i get a whining sound for about 5 too 10 seconds then it stops the sound for cable is working but no pic. then the tv...
Hi:
This sound is an indication that the color wheel is faulty in the light engine, with mits sets you must replace the entire optics engine. You can purchased used light engines or have your sent in for repair. Try this site for rebuilt engines www.tristatemodule.com
Mar 10, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
HOW DO I RESET MY TV
With the Mitsubishi remote : Menu, 1,2,3 enter
There is also a hard reset by the one above (soft reset) should be tried first----
Let me also know the reason you are trying to "reset".
If this information told you something you did not know rate this solution as very helpful as I do this here for free.
Let me know by responding here to this post if you have questions or need more help---I am here to help.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WD-52725 52". Rear Projection...
My WD-52725 Projection TV will not turn on. The
Where is the reset button on a 65 CD Mitsubishi HDMI TV
Jul 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
The green light keeps blinking on my WD 52725
Install The C26 DM and V26 Power repair kits available from www.tvrepairworld.com the kits contain the replacement capacitors and the CD with detailed repair instructions.
Dec 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Television suddenly turns off.
Try to get a firmware update. THis happened to me and I got a firmware update from Mitsubishi and now all ok. Call Mitsubishi
Nov 12, 2008 | Mitsubishi WD-52725 52". Rear Projection...
TV will not turn on
There are a few reasons that this could be happening first one is maybe the lamp died on you, Afraid there is no way to test this other than replacing the lamp. The second problem may be 5 capacitors on the power supply that hold the 12 volt line low and do not allow the light engine to start properly.
First thing you have to do is listen to how it trys to start, It should sound like this, first when you hit the power switch there may be a click then within five seconds the fans then a few seconds more you may here a sparking noise, if all this is happening then you most likely just have a bad lamp
Feb 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
464 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
