Question about RIM Cell Phones
I have a rim 7290 it has a devive error 365,I need to reset and do not know how.
  • 2,326 Answers
Try to remove the battery to reset the circuitry inside. If that does not work you might have a hardware failure in your device.
Posted on Jul 14, 2008
  • Jaime Hernandez Jul 14, 2008
    I would also suggest to contact your service provider as well, as indicated if you click here once you get that error.
    Check the info on this link.
  • 2,427 Answers
Http://media.wiley.com/product_data/excerpt/43/04717930/0471793043.pdf
There are all the secret codes, how to's and modifications anyone can dream of for the phone
Install adboe acrobat reader to view the file
YES the reset code is there
  • 1 more comment
  • Rishi Roshan Ali Jul 14, 2008
    Adobe Acrobat Reader
    www.adobe.com
    what hardware failure???
    how does removing a battery reset the device ???
    Removing the battery helps if the phone is frozen ,, it does not reset it
My RIM Blackberry 7290 comes up with "Device Error: 365 Reset". Whatever key I push, it still comes up with the same message.This problem started after taking the battery out to insert a sim card. Tks
you probably either messed up your battery, scratched your sim card, or got something wet. i would ask a phone technician cause you might need some help.
Dec 15, 2009 | RIM BlackBerry 7290
My Blackberry 7290 won't turn on
Hi, The BlackBerry device is unable to complete the initialization process, the Device Error 365 Restart error occurs To resolve this problem, you need to follow the steps below: Attempt to run Application Loader. Application Loader will remove the BlackBerry Device Software (both the operating system and Java applications) completely and reload it.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
Devce eror 365 reset
In alot of cases Device Error 365 means the unit is dead.
365 is hardware error. Some cases it has been resolved with forced OS reload, but in many cases it's dead
Jul 09, 2009 | RIM BlackBerry 7290
Dvice error 365 reset
In alot of cases Device Error 365 means the unit is dead., it's not ever gonna work again.
May 31, 2009 | RIM BlackBerry 7290
Solution for 7290 blackerry frezzes up how do i reset?
Try resetting the phone by powering off, removing the battery leaving for 30 seconds reinserting the battery and powering on.
If that doesn't work hold down ALT+RIGHT SHIFT(CAP)+DELETE keys simultaneously unti you get a blank screen.
May 11, 2009 | RIM BlackBerry 7290
My blackberry 7290 Rim(T-Mobile)says: Device error
An unspecified error has occurred with an application on your Blackberry smartphone.
Resolution In BlackBerry Desktop Manager, run the BlackBerry Application Loader tool.
Note: The following procedure will delete all data and applications from your BlackBerry smartphone.
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
    1. Remove the battery cover.
    2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
    3. Replace the battery cover.
    To perform a hard reset on a RIM 850 device, RIM 857 device, RIM 950 device, or RIM 957 device, insert the end of a paperclip inside the small hole on the back of the BlackBerry device.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Mar 01, 2009 | RIM BlackBerry 7290
Error 365 showing blackberry 7290
Hello Sir
To delete all the data, go into Options / Security Options / General Settings, clik the wheel and then click Wipe Handheld.
This will remove all of the DATA, and not any of the applications.
Feb 21, 2009 | RIM BlackBerry 7290
Error 365
reflash it with bb desktop manager and latest firmware found in the support or from here http://www.blackberryforums.com/rim-software/1871-blackberryos-4-x-download-faq-upgrade-downloads.html
Jan 14, 2009 | RIM BlackBerry 7290
Dicice error 365
pls Send Solution
Sep 09, 2008 | RIM BlackBerry 7290
7290 device error 365 help me
i am facing same issue error 365
Apr 09, 2008 | RIM BlackBerry 7290
Cell Phones Logo
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
