Question about Kenwood KAC-859 Car Audio Amplifier
Amp Problems My MTX Audio Class D amp. Im JUst getting a flashing red light. The deck will also flash at the same time as the amp. Any Ideas????
    Problem Solver:
  • 13 Answers
Unplug the stereo input signal from the amp. If the amp does not do it with the wires unplugged, you may have a problem with the radio sending too much voltage to the input of your amp causing it to go into protect mode. If it continues it is in your power source to the units. Let me know and I'll see what Ii can do. Hope this helps...
Posted on Oct 17, 2008
Why does my MTX thunder 702x amplifier cut on and off
Check fuse on amp under hood. Also, check wire connections makes none of them are loose and move your RCA jacks around to see if you have a short.
Jan 04, 2012 | MTX X Thunder 702X Car Audio Amplifier
I just replaced my old terminator 12" subs with two new 12" jl audio w3 4ohm subs and the mtx terminator amp keeps shutting off and flashing red. I kept everthing the same from my original mtx...
You may have touching speaker leads going into the amp. Make sure the tinsel is not touching across the speaker inputs on the amp. Also check your ground. It should be solidly connected to the vehicle chassis in a paint-free location. Finally, make sure there are no exposed speaker wires touching the vehicle chassis.
Mar 09, 2011 | MTX Terminator TN400/4 Car Audio Amplifier
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
Jan 31, 2011 | MTX Thunder 3401 Car Audio Amplifier
My amp i just instaled is a terminater mtx 250 watt amp and the lights are flashing instead of a constant red i checked my power and ground what else would it be
Check your remote wire on both the deck and amp... If the remote wire is loose it will turn the amp on and off constantly... Also check to make sure that the fuses on the amp it self are properly seated.
Oct 30, 2010 | MTX Car Audio & Video
Amp won't turn on, red light on amp is flashing
DID THIS JUST HAPPEN ALL AT ONCE ? OR DID IT GRADUALLY HAPPEN? CHECK GROUND FROM AMP , INSTALL ONE FARAD CAP . STOCK RADIO ISNT REALLY HELPING , MOST AMPS OF TODAY TAKE A HIGHER SIGNAL FROM HEAD UNIT . ADD ONE FARAD CAP AND SEE
Jan 17, 2010 | Car Audio & Video
Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
Sony Wega TV
9 times flashing light shows error in Audio Amp section. Please check Audio Amp IC and related parts including +&-19 volts supply line to this section.
Though its technical reply yet I hope it help you.
Aug 07, 2008 | Televison & Video
Not working
Make sure the remote (rem) port is powered, if not take another look at your inputs from the head unit as sometimes we tend to forget the channels orientation of ground and positive left and right.
If all else fails, have an audio installation expert help you out, a pari of extra hands would be helpful too...
Dec 09, 2007 | Pioneer GM-X372 Car Audio Amplifier
Kenwood KAC-859 Car Audio Amplifier Logo
165 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
