Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Code F2 I just replaced the door switch on an inoperable DD-602. My top drawer was working fine, but my bottom one has been offline for a while (door switch failed and I never got around to fixing it since I had the top). Well, my top finally failed too so I replaced both switches. Looks like everything is good on the top, but my bottom is erroring with an F2 code now. Kindof makes a thumping noise as it starts the cycle -- maybe 3-5 short thumps and then a 10 second delay, repeats. Any ideas? Could I get a copy of the service manual too? chris@seekonk.org
  • westwood293 Jul 21, 2008
    Makes a thumping sound and displays F2. Bottom drawer only. Top drawer works. Same exact problem as Chris
  • wabbada Aug 13, 2008
    Same thing happened on the top draw of our DD603 unit.....F#? appeared, but worked ok after openning and closing..then one night heared a big loud clunk..next morning no power to top unit and can't open.  Bottom unit working ok.  Just need to open, clear insides out and fix the thing.  Any ideas on how form the front?
  • 770 Answers
F2= The motor has not
been sensed rotating
 Foreign object has jammed the rotor
 The rotor has failed
 The hall sensor has failed
 The electronic controller has failed
Please check your email
Posted on Aug 05, 2008
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a f1 come up and a f2 on my dishwasher what is it
f1 = Flood Code
This means that the dishwasher most likely has a leak
There is a float switch in the bottom of the machine and when water gets down there it trips the code
F2 = Roter not moving
you can remove the basket and spray arm and pull the roter out and make sure its clean and give it a try.
Jan 21, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Our machine has F1 error what does this mean please
The cause will depend on whether the F1 is showing in both drawers or just one - which one?
It is caused by the flood switch located on the base to trigger and is usually due to water leaking. In some cases it is linked to thermal fuse blowing in bottom drawer, but in that case will show up only in top drawer and bottom drawer will have no power.
Hope this helps.
Sep 14, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
I have a F&P Model DD602I. I had a repairman out to change out hoses that were bad and now I have this problem: When I just run the bottom unit, it works fine, but a bunch of water ends up in the top...
Try to isolate the drain hose of the top drawer by disconnecting from the U hose. Run the bottom drawer.
Similarly isolate bottom drawer and then run top drawer.
See if problem is linked to back flow from drain.
I am assuming by now you may have already solved the problem.
Aug 15, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
My top drawer won't start. it doens't seem to
Most likely problem is the drawer close sensor mounted at the back of the housing is faulty. The lock function on these is electronic and unless the controller detects the drawer has closed it will not start the lock motors.
You will have to replace the sensor to make this work. There is a possibility the drawer may have come off the rail and therefore not travel to the end. This can be checked by inspecting the travel of the drawer.
In any case you will have to take the drawer out from the housing. see page 7 step 2 of the installation manual for this. This is for a later model but your model should be similar.
Jul 02, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
TOP DRAWER WAS NOT DRAINING..NOW THE F1 ON BOTH DRAWERS IS ON
F1 code indicates a leak,you will find the water under bottom drawer.Lid probably not sealing well.
Jun 17, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher & Paykel DD601 top drawer won't start. When start button pressed dishwasher just makes a beeping sound and will not start. Bottom drawer works normally. Any help appreciated.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
Jun 05, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
F1 Switch
No it is not a switch it is contact on the board in the bottom of the unit turn the power off and slide the bottom drawer out and dry up the water with a towel
Mar 29, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Water comes up into top drawer
seals are worn out you most likely need to replace due to hard water or solvent break down this product is known for bad seals
Dec 06, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Water not draining from drawer
Could be the little non return valve mounted underneath the top drawer. Lie down on the floor under the top drawer, remove the main plastic pannel covering the bottom to expose the black drainage hose (you may need to cut away a cable tie). Remove the drainage hose from bottom of the drawer - at the start of the drainage hose there will be a small rubber type flap - if it looks broken or worn out, it will need replacing - call F & P for a replacement, approx $5 + postage for a pair (one for the top drawer and one for the bottom)
Hope this helps
Nov 03, 2007 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
206 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
