FixYa.com
Tags:
PC Desktops
Generic problem for all PC Desktops
Linksys n router model wrt160n
posted by rksiwek on Jul 14, 2008
linksys n router model wrt160n will not install. Internal error message.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 14, 2008
Helpful (85)
spincycleus
Rank:Apprentice Apprentice
Rating: 89%, 4 votes
what is the internal error message, (error 500?)
and im assuming you're using the disc
take that thing out and click on start, run, type cmd and click ok
black window pops open
type ipconfig and see what your gateway is
it should be 192.168.1.1
if default gateway is blank
type ipconfig /release (there is a space between ipconfig and the / mark)
ipconfig /renew (there is a space between ipconfig and the / mark agian)
type ipconfig again, if still no gateway
click start, control panel, net work connections, right click your local area connection and click properties.
In the window where its talking about client for microsoft networks, double click the bottom line that says internet protocol TCP/IP
in the window that pops open, make sure you have the box marked by 'Obtain an IP address Automatically',
and press ok and ok again.
ping 192.168.1.1
if you get a
reply a;ljf;alsjf;aslkdfja;
reply alsdjfalsjfd;asljdfk
reply lasjkdfal;sjfds;lfj
reply alskfjalsjf
(4 replys)
then your computer sees the router
if you get back a message that host is unreachable, you can check to see that your nic is ok by typing
netsh diag gui
and clicking ok
a help and support window opens eventually
click 'scan your system'
when its done, look down at the bottom at modems and network adaptors
at the right, if its blank or fail, is bad
if pass, then you need to maybe try new ethernet cable, and or reset the router
also, try to set it up in safe mode, a firewall may be blocking you
click on start, run, type msconfig and click ok
a system configuration utilities window opens
click on the boot.ini tab
put a mark by network
move 2 to teh righr and put a mark by network
drop down and click apply and move left and click close
restart the computer
it will come up in safemode
click on your user account and click ya when it asks
do you want to run in safe mode
when you in safe mode, open internet explorer and type 192.168.1.1 and see if you can access the router
the username and password are both admin
if you have DSL, set it up for PPPoE on the basic set up tab and put in your username (your email address like paul@att.net) and your password)
click save changes at the bottom and continue
click the status tab and if it says connect, click it
if it says disconnect, leave it alone and open antoher internet explorer window and go to yahoo.com to see if you online
if you are, click start, run, type msconfig and click ok
when the window comes open, click on the boot.ini tab again and unmark safeboot, click apply and close and restart the comptuer to get back to regular mode.
hope this helps alittle
spin
then yor
spin
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP Pavilion a800n (PP163AA) PC Desktop HP Compaq Presario SR1220NX (PJ517AAR) PC Desktop HP Compaq d530 CMT PC Desktop HP Media Center m7250n (ED842AA) PC Desktop HP Pavilion a400n (DQ173A#ABA) PC Desktop HP Pavilion s7310n (EN996AA) PC Desktop HP Compaq d220M (829160054797) PC Desktop
Can you Help with these PC Desktops problems?
Sun SPARCstation 5 PC Desktop
SUN SPARCstation 5 Desktop
I have a SUN SPARCstation 5... Answer This...
PC Desktops
My Medion TFT 15" LCD
My Medion TFT 15" LCD... Answer This...
PC Desktops
I have a Compaq Presario
I have a Compaq Presario R3000... Answer This...
PC Desktops
I have an acer aspire
I have an acer aspire and am... Answer This...
PC Desktops
Trying to install Belkin...
Trying to install Belkin... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
