Question about Dometic Rooftop RV Air Conditioner
Low Voltage My campground seems to suffer from low AC voltage. How low can the voltage go before I have to start worrying about harming the unit. I think I read somewhere 10 or 15% of rated voltage is acceptable, is this correct?
  • 828 Answers
Yes the 10% factor is correct. Anything greater than ten 10% will affect operation without question.
Posted on Jul 18, 2008
Ac going to both indoor and outdoor units. Compressor unit runs if relay pressed manually. Indoor unit does not have any lights on and does not respond to the remote or test/emergency switch..
Sounds like compressor contactor won't pull in due to the low pressure switch. You have to find where you're losing voltage. Unfortunately sounds like a refrigerant. Voltage not making it all the way to contactor. Low voltage not high voltage
Jun 07, 2016 | Heating & Cooling
Rear ac unit keeps kicking off says low power the fan will run on auto soon as u kick on ac or heat it kick of and says low power front unit runs good dometic unit
Check your breakers and make sure you are getting the required voltage. Sounds like you are not getting the correct voltage to the system.
Jul 13, 2014 | Heating & Cooling
Heater blows no heat
  1. check to see if you have voltage to your blower motor with key on and blower motor switch selected to a speed setting
  2. if you have voltage, then your blower motor is faulty
  3. no voltage means that you have a blown fuse, bad relay, bad fan switch, or bad blower motor resistor.
Dec 10, 2013 | Cadillac Eldorado Cars & Trucks
What do they mean the input voltage range between the wall outlet and this adapter is ac 100v-240v, and the adapter's output voltage is DC 5V,2A
A lot of new computer hardware will accept regular 110-115v like most people have in their homes (USA) or high voltage 220 (mostly used for washer / dryers) or industrial use. Like in a factory. This unit accept both without worries of over loading. Some may even have a switch to swap back and forth. It actually only uses 5v and 2amps. Meaning a single 110-115 power strip can handle many plugs, because of the low voltage.
Aug 28, 2012 | ASUS Google Nexus 7 16GB Tablet 71B16
Unit only works off battery, not AC.
there may high voltage or low voltage, ups goes on battery when high voltage and also goes on battery when low voltage acceptable range of window is 90vac to 130vac for 110v i/p
Mar 06, 2010 | CyberPower OR1500LCDRM2U UPS System
I have a goodman furnace and ac unit the fan and heat work but every time i turn the ac on it blows the low voltage fuse ive replaced all low voltage wires to outside unit and thermostat i also replaced...
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Unit shuts off automatically after power on.
You have an internal short in the electrical line. your wall a/c [120 volts] goes inside and is converted [changed] to DC [ like a super battery] There are a lot of connections coming out of this POWER SUPPLY[super battery] to FEED other electrical circuit. ANY one of the circuits can demand more then power supply can give and will cause it to SHUT DOWN [turn off to protect itself]
unless u know what u are doing [" DANGER!! wILL rOBINSON, DANGER!!] you should not mess with it.
Jan 19, 2008 | Toshiba MD13M1 13 in. TV/DVD Combo
SMART UPS APC 3000
let the ups be turned on just charging the batteries, u can have the voltage but the batteries still not fully charged. good luck
Feb 27, 2007 | APC Smart-UPS 3000R3BX (SU3000R3BX135) UPS...
Dometic Rooftop RV Air Conditioner Logo
143 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
