Question about Hitachi 60SX12B/13K 60" Rear Projection Television
Blue line wont adjust
Hi the blue line on my hitachi 60'' wont adjust. i tried magic focus and i also tried doing it manually. i managed to adjust my red line but when i try to adjust my blue it just wont budge at all. i checked all the lights on the board and they all seem to come on. can anyone help me out with this problem. i was thinking it could be the STK but im not quiet sure can u tell me if i am right or if it can be soemthing else. thanx
  • 1 more comment
  • Angel Martinez Jan 10, 2009
    what hould be the best ic to use. the stk 392-110 or 392-150
  • Kathy Chinander Jan 11, 2009
    Hitachi 60 " what is the 6 feed resistors?
  • Kathy Chinander Mar 06, 2009
    I replaced both convergence ICs and the 6 feed resistors and I still am not able to adjust the blue line? The top of the screen and bottom have an arch with the blue lines? Any other suggestions?
  • Hitachi Master
  • 8,617 Answers
You will need to replace both convergence ICs and the 6 feed resistors. If you need more info let me know
Posted on Jul 14, 2008
  • Sonny Berry
    Sonny Berry Jan 10, 2009
    The STK392-150 are the better as the run cooler which translates into lasting longer
Magic focus on my 60" Hitachi isn't working.
If your magic focus is not working your convgence has failed. Read this Tips page here on fixya for more details.
Jan 22, 2013 | Hitachi Televison & Video
How do you line up bulbs with remote
This set with front grill removed has a tiny blue button on front edge of chassis on left side that will manually take set to convergence mode but you must have the Hitachi working remote to do adjustments---different buttons on the remote adjust and save the adjustments, I have the Hitachi book that shows all remotes they use and which buttons do what---if convergence is real bad most likely the two chips for convergence need to be replaced if Magic focus will not help.
Oct 14, 2012 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 51F500 magic focus wont work, blue has "dropped", when I use the magic focus on auto it does nothing, when I use manual focus the grid has the blue scooped down and I can't seem to get it back in...
Sounds like your blue convergence module is faulty along with a few resistors. There is two convergence modules in your set(stk-392-020) and when one fails, the both of them are usually replaced with a matched pair .If you have a good knowledge of electronic you may replace them yourself.otherwise you`ll need the help of a tv repairman. Hope this help. Good luck
Nov 17, 2009 | Hitachi 51F500 51" Rear Projection...
Blue lamp is not in focus
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi projection tv 53SDX01B is out of focus how do you reset.
if magic focus will not correct convergence problem look in the customer menu for the word CONVERGENCE---IF BLUE WILL NOT ADJUST IN some direction, one of the two Stk-392-110(or 392-150) convergence Ic chips are bad; you may also find some burnt or discolored resistors behind them----this kind of problem is usually fixable right in your home; if you need direct help;;;
etower.766@netzero. net
If this was helpful I would appreciate a vote from you here.
Aug 14, 2009 | Hitachi 60V715 60" Rear Projection...
Blue outline on the top half of the picture on my Hitachi 51F500
your convergence ic is going bad. usually worth the repairl.
Jun 04, 2009 | Hitachi 51F500 51" Rear Projection...
Screen prob with Hitachi 51UWX20B red square
Maybe the best way to adjust the screen is with the manual magic focus..instead of letting the tv do the auto change it to manual and see if you can adjust the convergence yourself. I have this same model and once in the manual adjustment you want to make sure you see all white lines....if you seen any blue or red that is the color that needs to be moved towards the white line closest.
Once you think you have it lined up nicely hit "exit" on your remote and option 1....
Hope this helps you.
May 05, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Looks like the picture is in 3D...magic focus won't adjust green
Replace Both of your STK ICs they are Big Black ICs Also CK and replace these resistors RK42 3.3 /RK46 1.8 /RK50 2.7/ RK54 1.5 RK54 1.5/ RK58 3.9 /RK62 2.2
Feb 15, 2009 | Hitachi 57F500 57" Rear Projection...
Blue/Yellow out of focus on Hitachi 43UWX10B
You will need the convergence circuit repaired......IC's replaced,
B+ resistors checked and then magic focus activated......T.
Sep 17, 2007 | Philips 60P8342 60" Rear Projection...
Televison & Video Logo
197 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
