Question about HP Office Equipment & Supplies
I HAVE A D135 HP ALL IN ONE PRINTER. IT WILL PRINT FROM THE COMPUTER, BUT NOT COPY ANYTHING. SAYS THERE IS A SCANNER FAILURE. TELLS ME TO TURN IT OFF AND RESTART IT AGAIN. BUT THAT DOESN'T MAKE IT WORK THE ERROR MESSAGE REPEATS ITSELF. CAN THIS BE FIXED IN SOME WAY?
  • JOTAXES Jul 14, 2008
    I WILL TRY IT OUT, TO REINSTALL THE SOFTWARE
    Genius:
  • 2,035 Answers
Please unplug the power adapter from the printer wait for 10 mintes and then plug it back to scan if this fails then unplug the usb cable and reinstall the drivers of the printer.....and then try to scan
Good luck....
Posted on Jul 14, 2008
    Brigadier General:
  • 6,966 Answers
It would seem that your PC is not communicating properly with all the sub system of the all in one. It would then be necessary to uninstall completely all the functions/drivers of the D135 either/and in Add/Remove (Control Panel) and/or in your Printer & Faxes. Thereafter reboot without the D315 connected to the USB. Reinstall but temporarily disable your antivirus and firewall while doing so. Follow on screen instructions. At a certain point wou will be prompted to connect the printer and power it on. You may gain be ask to reboot. Once everything checks out, re-enable your antivirus and firewall.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 14, 2008
    This is of course assuming no hardware issue.
    Genius:
  • 1,665 Answers
It may not cost effective to repair
    Genius:
  • 1,847 Answers
Reinstall the printer software and drivers.
  • Legin Varghese
    Legin Varghese Jul 14, 2008
    OK..
    Clean the scanner head and glass
    Removing the scanner glass
    General
    The Automatic Document Feeder (ADF) will need to be removed before the glass can be removed. You will also need a T10 Torx head driver approximately 6" long. Driver handles that accept removable bits may be too large in diameter for this particular job.
    Removing the automatic document Feeder (ADF)
    1. Hinge the ADF upward as if you are going to manually scan a document.
    2. In the hinge area there is two black pull latches. Pull them up and lift the ADF straight up to remove it. Some side-to-side rocking may be necessary before it will disengage.
    Removing the Scanner Glass
    1. Remove the four T10 Torx head screws around the perimeter of glass, i.e. two in the ADF hinge area and one on the right and left.
    2. Remove the Control Panel overlay. It pries off.
    3. Open the printer as if you are going to access the cartridges and disengage the support legs. Two latches at the base of each leg must be pried outward with a slot style screwdriver to disconnect them. The scanner assembly will now "flop" freely, so steady it while removing the four screws on the underside.
    Note: The screw in the front is hidden under the piece that you grasp to gain cartridge access. Two latches must be released to remove it. The screw can now be seen using a flashlight but may be obscured by some wires.
    Clean the underside of the glass, giving particular attention to the white strip. Then clean the scanner bulb (gently, its thin glass) and the mirror(s) with a cotton swab sparingly moistened with Windex or a similar cleaner.
Hey. I have a HP Officejet d135 All i One, and running Win7 on my computor. The scan function on the device does not work. The display on the printer/scanner reads "Scanner Failure. The scan function...
Go into Device Manager and double click on USB Print Support. In Driver tab, click uninstall. After uninstall, power reset the computer. Once computer turns back on, it should automatically start the re-installation process of the printer. Then you select let windows do automatic search for the proper driver.
Mar 01, 2011 | HP OfficeJet D135 All-In-One InkJet...
Officejet j6480 gives error msg scanner failure cannot copy, scan but will print from the computer
On the top of the scanner mechanism, there is a black tab that gets caught on the underside of the scanner surface, just beyond the glass, towards you. You will hear a gear grinding sound, that"s the tab getting caught. either bend the tab down, or remove it. Its on the black cover that"s on top of the scanner mechanism. Also remove any tape that is on the bottom of the trailing cable under the scanner that prevents it from moving all the way to the left.
Dec 18, 2009 | HP OfficeJet D135 All-In-One InkJet...
Scanner failure
Scannerfejl. Kan ikke tilslutte til PC
Aug 05, 2009 | HP OfficeJet D135 All-In-One InkJet...
Displays " Scanner Failure"
I've seen a similar issue on other HP All-In-Ones. I had to contact support, but all they do is make sure you try connecting the printer to the wall outlet instead of a surge supressor, then a different wall outlet, then reset to factory defaults. After that didn't work, they submitted an replacement order.
Hope this helps
May 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
Scanner failure
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Aug 14, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner failure
1. Check scanner light by trying to make a copy.
Caution: do not look directly in the light
3. Perform a power cycly
* Unplug the power cord from the product while its still on
* Plug the power cord back again after 30 seconds
4. Perform a semi-full reset
* Press and hold # and 6 while plugging the power cord
* Do not release the button unless the printer would say reset
5 If you still have the problem replace your printer
Aug 12, 2008 | HP OfficeJet D135 All-In-One InkJet...
"Scanner Failure" displayed on led panel EVERY time
The solution is at the HP website. see here
Solution five: Reset the product
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Oct 28, 2007 | HP OfficeJet D135 All-In-One InkJet...
26 people viewed this question
Ben Johnson
