Question about Sony Playstation 3 (PS3) Console
Make connetion stroonger
My wireless connection is not strong enough so how do i make it stronger
Buy a re-peater or a internet expander. look it up at walmart.com
Posted on Jan 07, 2009
    Problem Solver:
  • 6 Answers
Well, for one, you could move your internet tap closer to your system.. if that is the case already, try to eliminate any piece of furniture or wall or w/e blocking/reducing the signal from your router to your system. if all else fails, try out a direct connection. they're always 90% to 100% signal strength, and a splitter only costs about $20. along with a 100ft. cable and your total is around $50(depeding where ya go) i have a direct connection and love it.. so uh try those out and gimme some feedback.
-Evan F
Posted on Jul 14, 2008
Wireless cuts out
Try moving closer to the router and see if it cuts out. If it stays connected you probably need a wireless adapter that can give you a stronger signal. You can purchase a usb wireless adapter for under $30 that will give you a strong signal and good connectivity at www.tigerdirect.com
Mar 29, 2012 | Computers & Internet
I purchased a router linksys by cisco model wrt120n wireless home router, i leave on a 2 story house of concrete. my problem is i can not used my laptop on the first floor.. i look on the unit of my router...
You can use WAP4410N Access Point in Repeater Mode with WRT120N to extend the wireless signal.
You could also try the Hawking HWREN1 Hi-Gain Wireless-300N Range Extender.
Another route you can try is Linksys WMP600N High-speed Wireless-N PCI Adapter with Dual-Band.
These devices should each be able to give you a strong enough signal, if placed properly, to connect to your Router.
Mar 08, 2011 | Linksys WRT120N Wireless Router
Signal is not strong enough to connect laptop downstairs away from Linksys 2.4 ghz wireless router in my home network. I have ethernet downstairs, can I attach another wireless router, as well as my PC to...
Looking at the specs for that Linksys router, it is a "G" size router. Most "G" routers only have an average indoor range of 150 ft. and that also depends on what type of construction materials are in the home that could hinder that range and the signal. Another router attached would only degrade the signal even more, that is not recommended. A stronger ranged router would probably be a better solution, possibly an "N" or "N+". Hope that helps.
Jan 22, 2011 | Computers & Internet
My wireless router isnt working. I have a NETGEAR Wireless-n 300 Router with the label WRN2000. Is this a strong router and can I get a stronger one that produces the capability to use more wireless...
That is a good router.
Is your wireless device (iPad? laptop? notebook?) using a Wireless-N adapter?
If not, all you get is the much-slower "Wireless-G" speed.
Measure, measure, measure.
If you use an Ethernet cable to connect from your computer to your router, do you get a much-faster connection?
How far (and how many walls) between your router and your computer?
Dec 14, 2010 | NetGear WNR2000 Wireless Router
Signal not strong enough can I boost it
The "Wireless / Advanced" configuration window contains a setting for transmit power. Be sure it is set to 100%.
Otherwise, your only options are to replace the antenna with a booster antenna, or to add a stronger wireless router as an access point to your current setup. Using a booster antenna requires the D-Link to have a removable antenna, which it may not have -- none of the documentation calls this out as a feature.
Keep in mind that if you are trying to use this router over excessive distances, boosting the router's own power will not necessarily improve your connection, because the broadcast power of the remote PCs is also a limiting factor.
Dec 02, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Connection is not strong enough for any internet
this link will give you a good start to attempt to obtain a better wireless connection.
hope that helps
Dec 27, 2009 | Linksys WRT54GC Compact Wireless-G...
I have a Toshiba L25 laptop and a D-Lin Air DWL-650 wireless card. I'm not getting the best connection with the wireless card while my other computer has a much stronger signal. I'd like a recommendation...
im assuming its a cardbus adapter right? well that model is a wireless b signal, which isnt very strong, so any wireless g model should have a much stronger signal. it doesnt matter which one it is, as long as its wireless g, which most new cards are. hope this helps, goodluck
Jul 09, 2009 | Toshiba Satellite L25-S119 Notebook
My Linksys network adapter is very slow to connect
Ask them to review you connection speed to make sure your getting the speed you ordered. Linksys is usually pretty good. See if it's faster WITHOUT using the wireless (plug directly into the modem). If it is I can only think of two things... Ether you need to relocate your wireless modem to acheive a stronger signal OR if your signal is strong on your adapters end, you could always upgrade to a different wireless adapter that can handle faster conections.
Jun 27, 2009 | 2wire (1000-400108-001) Router
Choosing a stronger router
You can get this one its WRT300N this a router that uses the latest wireless N technology which means a wider range and faster speed but using this router in order for you ro use the wireless N technology you may need a wireless N adapter also on your computers.
But if you want since you already have a existing wireless network juts get a wireless range expander to repeat the signal of the router so it will reach your XBOX this is the model WRE54G.
May 16, 2008 | Linksys Wireless-G WRT54G Router
Wireless router
I think 2wire routers are good in providing signal strength. Contact the 2wire vendor regarding your requirements.
take care
May 01, 2008 | AT&T High Speed DSL Modem
Sony Playstation 3 (PS3) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
