Question about Microsoft LifeCam VX-3000 Web Camera
Usb not recognized
Works for 10 minutes, then usb not recognized
  • 3 more comments
  • Anonymous Jul 23, 2008
    my usb is not recongized
  • Anonymous Aug 09, 2008
    I am with XP SP2, same thing, usb not recognized
  • cameracrew23 Dec 05, 2008
    i have a new video camera and whenever i plug it in it says it doesnt recognize the device
  • Anonymous Dec 18, 2008
    i have the same problem
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this on a Vista computer?
    President:
  • 8,637 Answers
Normal 0 Probably has corrupt driver.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
Posted on Feb 05, 2009
I have pendrive with 32 gb. It was worked for 2 days only. Now its not recognizwd by windows. what can i do.
Considering that if the USB is fine and and working systems, here is simple solution! Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that?s it! Note that this does not mean just turning off your computer because modern computers don?t really turn off when you press the power button as the motherboard still gets power. First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be ?rebooted? also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices! So, first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Remove the battery and press and hold down the Power Button of your laptop for a few seconds. Let it sit for about a minute and then plug it back in. Hope this helps someone fix that ?USB device not recognized? Windows error!
Otherwise if the USB is faulty you may claim the warranty as the USB Pendrives are usually under 10 months warranty cover.
CreativeTECH
Jan 03, 2011 | Computers & Internet
USB d0es not recognize the web cam
just try to format your system and try to install the cd given for webcam
Jun 24, 2008 | Microsoft LifeCam VX-3000 Web Camera
Transcend 160GB Portable Hard Disk is not recognized by computer
when you power up the computer press F2 or "del" key to enter in bios then go to usb option and enable usb 2.0 legacy. then save settings .
then check.
some times usb speed make issue so try this.
Also check your usb cable working fine try with other usb cable.
Also check harddisk jumper settings.
If still face problems then you need to repair it.
You shuold take it to service shop becasue you try with 10 computers and all gives same error then your harddisk has hardware issue.
try above solution .
Thanks for using fixya.
Please rate my solution if it helps you.
Jul 20, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Usb flash pen drive
Often it is due to electrostatic charges on usb. Unplug all USBs.Unplug PC from power cable for 10/15/ minutes. plug back computer to power outlet and restart. Plug back usb.
If it still does not work , flash memory may be faulty, test it on a different computer.
Mar 17, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Won't Upload Songs
player has problems with windows media player 11. works with wmp 10. player also has problems with vista. firmware was designed for xp. no firmware updates available. you can try dragging and dropping through windows explorer, treating it as a usb mass storage device. it will play folders and songs this way. to get vista to recognize it, format the player through the player's menu ( set-system-format ) not through the computer. take out the battery for 15 minutes. reboot your computer. put battery back in. plug into usb port. hopefully vista recognizes it as usb device
Nov 02, 2007 | Panasonic SV-MP020 MP3 Player
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
Sep 28, 2005 | Apple iPod nano
Microsoft LifeCam VX-3000 Web Camera Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
