FixYa.com
Tags:
PC Desktops
Generic problem for all Gateway PC Desktops
Gateway laptop problem has been
posted by Rolaunda on Jul 14, 2008
Gateway laptop problem has been detected and Windows keep shuting down to prevent damage to computer. What shall I do? Norton has currently been added.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 14, 2008
Not Rated (0)
spincycleus
Rank:Apprentice Apprentice
Rating: 89%, 4 votes
start your computer in safe mode.
Click start, run, type 'msconfig' in the box without the commas and click 'OK'
a system configuration utility window pops open. Click on the tab at the top in the middle that says 'boot.ini' and put a mark by safeboot. Drop down and click apply, move left and click close. Restart the computer, you will come up in safemode. If you dont get the same problem, is probably norton, norton wont start in safemode unless its the corporate edition.
to get back to regular mode, click start again, click on run, type msconfig and click ok. The system configuration utility window pops back open. Click the boot.ini tab and unmark safeboot. Drop down and click apply, move left and click close. Restart the computer. It will come back up in regular mode.
a work around if it is norton would be to remove norton and try AVG antivirus, is free
it problem persists, then it wasnt norton. Norton needs quite a bit of memory to run. If you dont have at least 512 mb in your system (more if your video card uses part of it), then you going to have problems.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Gateway E-6100-V1 PC Desktop Gateway E-6100-V2 PC Desktop Gateway E-6100-F1 PC Desktop Gateway E-6100-F2 PC Desktop Gateway E-4300B (2900724) PC Desktop Gateway E-4300D (2900765) PC Desktop Gateway E-6100-HS PC Desktop
Can you Help with these PC Desktops problems?
PC Desktops
error code 0x900703e7 this on
error code 0x900703e7 this on a... Answer This...
PC Desktops
how do you get a
how do you get a computer out... Answer This...
PC Desktops
I am unable to connect
I am unable to connect my... Answer This...
PC Desktops
pc does not find portable
pc does not find portable hard... Answer This...
Acer AcerPower 1000 (AP1000EA380M) PC...
Acerpower 1000 - won't boot (or...
CD Rom LED light stuck on at... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
