Question about HP Office Equipment & Supplies
My psc 1315 all-in-one printer is not printing. all it does is to go back and forth and comes up with error all the time. is there any down load i can get to try to fix this problem as i have lost the original booklet.
I replaced both the inks and fiddled with the paper rollers and belts. this seems to have done the job. thanks for your help.
Posted on Jul 15, 2008
Cartridge stalled
You need to clean the rollers in the back panel of the printer.
Unplug the printer while it is powered on and remove the back panel. Get a damp cloth (not too wet) and wipe off the rubber rollers in the printer as well as on the panel. Replace the panel and open the front where you load the cartridges in. Move them back and forth from side to side and make sure nothing is blocking them from moving. Plug printer back in. It should come on by itself and initialize.
Print a page from your computer. It should now only feed a single sheet at a time without causing a carriage or paper jam.
Aug 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
my printer no function cant print
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Print Cartridge Error
Hello -
Did you perhaps not mean to post under the 1315? I am not sure if you have this printer or another model. The 1315 normally takes a different number ink cartridge.
Meanwhile - gotta tell you that the 1315 is the buggiest printer I ever had. If you purchased it recently and can find your receipt, I'd take it back! Since they've pretty much done away with the 1315, if it was a recent purchase, it was likely a clearance item from some place.
Try taking all the ink cartridges out, uninstall the printer entirely, and reinstall it (the entire printer, not just the cartridges). Blow your printer out with canned air as well - dust, pet hair, people hair, fuzz and general paper fibers can build up more than we think, and cause error messages and other printing problems.
That should help, if it was the 1315 model.
That being said, note that if it still doesn't work, and you have the 1315, save yourself a lot of grief and toss it in the trash and buy another cheap printer! 1315 is Bug City!
Jun 07, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 driver
how do free i down load hp 1315 printer software
Apr 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
20 people viewed this question
Ben Johnson
